Hitting rev limiter with 2800 stall!!!
Old Feb 15, 2003 | 10:17 PM
94hawk_klf's Avatar
I just installed a Midwest 2800 stall and 1-2 shift I'm hitting the rev limiter. I'm running street tires(pretty bald ones) and spinning VERY VERY badly, would this cause me to hit it?
I'm going to get better tires(DRs). Should this problem go away when I stop spinning so bad?
Thanks!
Old Feb 15, 2003 | 11:43 PM
94_formula's Avatar
you have the OBDI problem-
call bryan at pcmforless
you have a 7/10 chance that he can fix it
if not- OBII changeove or hello 2400 stall
Old Feb 16, 2003 | 12:50 PM
94hawk_klf's Avatar
Could this just be caused by the tires spinning so fast? Any other input?
Old Feb 16, 2003 | 01:22 PM
RamAir95TA's Avatar
94_formula is right. OBDI doesn't react well to stalls around or over 2800, and won't shift to second at WOT. Bryan has developed a sure-fire fix for the problem. Give him a shout at http://www.pcmforless.com
Old Feb 16, 2003 | 01:50 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
actually that was me on 94 formulas computer
joe- he develeped a sure shot solution?
i didn't know this
wow i guess joe > trey
Old Feb 16, 2003 | 02:05 PM
RamAir95TA's Avatar
Couldn't have said it better myself.
Old Feb 16, 2003 | 02:14 PM
OneFlyn95z28's Avatar
He may or may not have the problem. he metioned nothing about going limp after it did this?
I have seen on less effecent converters where they just Slip to much at WOT and can not reach the desired MPH for the shift due to Slip.
If he is spinning bad it is not un-common to bang the rev limiter ;0 i do almost every time I do a burn out in the box. I have been training myself to focus more on it
Good luck!
Old Feb 16, 2003 | 02:17 PM
RamAir95TA's Avatar
Nice post count!
Old Feb 16, 2003 | 08:20 PM
94hawk_klf's Avatar
Thanks for the input guys, I'll just have to wait until I get tires to see if that helps.
How much is the computer fix?
Old Feb 16, 2003 | 08:22 PM
GhostZ's Avatar
I have a 3200 stall from Midwest and programming from Bryan (OBD1 swap) and haven't run into any of the infamous OBD1/high stall problems.
Old Feb 16, 2003 | 08:45 PM
94hawk_klf's Avatar
GhostZ,
How much the programming?
Old Feb 16, 2003 | 09:09 PM
treyZ28's Avatar
Originally posted by RamAir95TA
Nice post count!
said the man with 7000posts in 6 months on fbody.com
Old Feb 16, 2003 | 09:18 PM
GhostZ's Avatar
Originally posted by 94hawk_klf
GhostZ,
I don't remember. Check www.pcmforless.com and there's a pricing sheet on the site somewhere.
It's not expensive and Bryan is a great guy to work with.
cristian1311
Apr 22, 2015 10:20 PM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
