ABS and low traction light
Old Feb 15, 2003 | 11:59 AM
96 camaro 4 life's Avatar
Hey, I've got a 96 V6 camaro and just recently the ABS light and the Low Traction light keep coming on while i'm driving. It only happens when i'm driving and it comes on when i'm turning or even just driving normally. I haven't really noticed anything wrong with the car besides the lights. Could it just be a sensor or somthing wrong with the brakes?? If you have an idea what could be wrong please let me know asap!! Thanx alot!
Old Feb 15, 2003 | 04:39 PM
nikkev's Avatar
Hmm,a couple of things to check:
-3rd brake light. (I think on '96 and later you'll get the ABS light when the 3rd bulb is blown)
-Altenator (when my alt went in my '95 I had those lights)
-ABS sensor
Good luck man.
Kevin
Old Feb 15, 2003 | 10:48 PM
Gossco95's Avatar
Yeah in my '95 Camaro when my Alternator went the ABS light came on..... but every once in awhile it will come on... does kinda get annoying so I just end up pulling over and restarting my car and it does that trick. But isnt a frequent problem. As for the traction light... never encountered anything like that.
Old Feb 16, 2003 | 02:32 AM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
the low track light comes on when the ABS is active. i would first check the 3rd brake light. i got an ABS INOP flash when it was out on my 93. if its not that i owuld have it looked at. but i dont know sheeet about brakes. if ya do, then give her a good look over
Old Feb 17, 2003 | 03:06 PM
3rd brake light?
what is the 3rd brake light and where is it? My alternator went about 8-10mos ago and i replaced it, so i don't think its the alternator, plus my bat seems to be holding a good charge. Thelights do go off when i restart my car and it comes on randomly when i'm driving. The other nigth when i was driving i tapped the brakes when driving at about 60k and they sorta locked up or something as if i had pushed the brake furhter down. They worked fine after that. Could it have anything to do with the actual brakes or the disks? I changed the pads not too long ago but not the disks. Any suggestions as to what could be wrong would be very much appreciated!
Thanx alot!
Old Feb 17, 2003 | 03:09 PM
scratch the part about the brake light
nevermind, i know what the 3rd brake light is, just wasn't clicking in.
Old Feb 19, 2003 | 10:20 PM
changed brake light
Well, it turns out that the 3rd brake light was burnt out, actually they were both melted and black. So i changed those and now I have now problems with the ABS INOP light.
Now its just the LOW TRACTION light. Ever so often, after starting my car and driving, when I push down the brake pedal the light comes on and my pedal doesn't go down all the way. I have to release the pedal and push it down again in order for it the brakes to work at full capacity. This has only happened in the first minute of driving when the car is still cold. If you guys have any ideas let me know, thanx alot!!
Old Feb 21, 2003 | 11:53 PM
cobra2550's Avatar
did you replace your pads lately?if so maybe you have the air in your brakes
Old Feb 22, 2003 | 12:05 PM
camaros_4_lfe's Avatar
changeing pads wont put air in the lines
sumthing is wrong with your your abs system and lowering your line pressure it sounds dont know much about them though sorry
Old Feb 23, 2003 | 12:38 PM
firebirdude's Avatar
Re: changed brake light
I had this problem. Try this: Roll down your windows and drive somewhere quite. SLOWELY come to a stop. Does the low trac light come on? Do the brakes feel strange at the same time? Now here's what you do.... listen. Listen for any noises. Do you here anything? hehehehe Specfically, an ABS motor? It's not real loud, but you can hear it easily. This tells us that infact the ABS is indeed kicking in. I advise you to check your wheel speed sensors. That's what was bad in my case. Help this helps!
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
