01-02 0owners inside
Old Feb 15, 2003 | 11:37 AM
My84Z's Avatar
found this on another board
If you own an 01-02 LS-1 F-body there is a chance you have the corvette LS-6 block tucked under your hood. Here is how to find out. First off, it has a much duller look then the LS-1 but if you have no way to compare go ahead and crawl under with a flashlight (I used a lift to check so idon't know how hard it will be to see) and on the back of the block at the top by the head on the driver side is a casting #. if it is 12561168, congrats, you have the LS-6 block. It is good for an estimated 20HP over the LS-1 and it is alot stronger. Sadly I have a plain old ordinary LS-1.
Old Feb 15, 2003 | 11:44 AM
6speedZ28's Avatar
This has been posted on other boards (ls1.com, slp's message board). It has been said the LS6 block is stronger...but where do u get that a block is worth 20hp?
Old Feb 15, 2003 | 02:59 PM
pg318's Avatar
The LS6 intake manifold is worth up to 20HP...The block is a little stronger, through redesign to overcome the weakening that the larger cast-in bay-to-bay breathing windows cause. There'll be a little less windage and oil whipping at high rpm compared to the LS1 block, but that'll not be worth much in output, just hopefully we'll have less problems with oil mist getting up into the breather. Shame they didn't rationalize to the LS6 lifter valley breather at the same time.
The LS6 block appeared in 01 Vettes, and seems to have been randomly dropped into 01 production of F-bodies, only becoming standard in the last few months of build (mine was built June)
Old Feb 15, 2003 | 06:30 PM
My84Z's Avatar
like i said i got it off another board i have a 2000 so it does me absolutely no good anyways
Old Feb 16, 2003 | 05:17 AM
2002Z28SSConv's Avatar
And another easier way to tell if you have one that has been posted here...
On the front passenger side of the block, in front of the intake manifold there is either a bullseye or a groove. I think the bullseye was the LS1. I don't remember for sure. I just woke up.
Old Feb 16, 2003 | 11:56 AM
NED4SPD's Avatar
Ok I looked to find a bullseye or a slash and I found nothing. I am very curious to which one I have. Someone help me find which one I got please! Zoran
Old Feb 16, 2003 | 12:16 PM
pg318's Avatar
There's a pic of both side by side here
Old Feb 16, 2003 | 05:36 PM
chuck's Avatar
The sad thing is, I don't care enough to go look
autoxr166
Sep 25, 2015 04:21 PM
karpetcm
Sep 15, 2015 11:07 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
