Key lock cylinder or ignition switch?
Old Feb 13, 2003 | 07:11 PM
BAD 97 WS-6's Avatar
Starting last week, When I turned the key, there would be a second or two hesitation, then the car's starter would kick in and start. During that hesitation, the car's power would seem to go but then the starter would kick in. Well now, when I turn the key to the "on" position, the lights on the dash do not come on (S.E.S light, ABS Light, etc) When I turn the key on, the radio and lights still work, but nothing else comes on. No Fuel pump, nothing. I just bought a new battery yesterday and it didnt fix it. Is it the key lock cylinder or ignition switch?
Old Feb 13, 2003 | 07:44 PM
I would say it points to the ignition switch. The gauge cluster lights and such are mechanically operated by the switch via the key cylinder rod and does not care if the cylinder can read the key pellet.
Old Feb 13, 2003 | 07:52 PM
Thanx.
Do you have an install page for that? Can I do it myself?
Old Feb 13, 2003 | 08:00 PM
I am working on a page. Not finished as yet. The best way is to remove the steering column. You can do it yourself. A manual could be helpful.
Old Feb 13, 2003 | 08:37 PM
AENIMA95z28's Avatar
pretty much same thing happend to me recently, couldnt start car, no idiot lights, nothin. Turns out it was my ignition switch, one of the metal terminals burnt out. Replaced Ignition switch and fired right up.
Old Feb 14, 2003 | 11:56 AM
arnie's Avatar
Is there an oem direct replacement HD version of the ignition switch available?
Old Feb 14, 2003 | 12:47 PM
Can someone give me instructions on how to change the ignition switch? The haynes book does not show how to fix it. I dont have to take the steering wheel off do I?
Old Feb 14, 2003 | 01:46 PM
Not that I know of.
The steering wheel does not have to come off. Doesn't the Haynes show where the switch is?
Old Feb 14, 2003 | 09:09 PM
No dude. My haynes book does not even mention the ignition switch. It does show how to replace the key lock cylinder though.
Old Feb 14, 2003 | 11:07 PM
Just finished ignition switch R&R. I kinda rushed it, so if you see any spelling or other obvious problems, email me. There has been a rash of these dying lately, so I though I would hurry it up.
Old Feb 15, 2003 | 01:18 PM
Dude, you are absolutely the best!!!
Thanx a million!!!
Old Feb 15, 2003 | 03:11 PM
FLII ME's Avatar
This happened to me last year, my car was having work done to it at the time. Its about a 1-2 hour job depending on experience.
Old Feb 20, 2003 | 06:20 AM
Thanx a bunch for your help. It was not as bad as I thought, and your web page was the main reason. Took me about 2 hours to do everything.
Heathen1
Jan 2, 2016 04:27 PM
robcarnut
Mar 20, 2015 03:40 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
