which o2?
Old Feb 19, 2003 | 09:17 AM
speedcrazy's Avatar
which o2?
i hear people say to use the acdelco ones but then i hear people talk about 2 wire, 3 wire and 4. what does my 95 lt1 trans am have on it now. i can't look cause the car is stored but i need to buy some new ones. so which ones to get? im gonna be doing headers in spring so its a good time to do those while im at it.
Old Feb 19, 2003 | 12:46 PM
anaik's Avatar
Get the AC Delco. GM #25312184. These are 4 wire. This is what I use and since we both have '95's, this is what you use.
Old Feb 19, 2003 | 02:46 PM
95 Silver TA's Avatar
Are these the sensors with the Flat pin 12 connectors OR the ones with a Sqare 4 pin connector?
And where is a good place to buy em relatively cheap?
Thanks,
Old Feb 19, 2003 | 03:09 PM
anaik's Avatar
[QUOTE]Originally posted by 95 Silver TA
Thanks,
[/QUOTE
I got mine from Dal about $37 apiece at lockitup@bright.net 877.448.5451
It is a flat 4 pin connector
Old Feb 19, 2003 | 03:21 PM
Thanks A Bunch...I just shot him an email.
Do you know if the o2 sensors for a 95 Trans Am are the same as an o2 sensor for a 96 trans am? The 'pre' cat one not post cat o2..
I want to make sure I am buying the right one.
Old Feb 19, 2003 | 03:59 PM
anaik's Avatar
I would think they are the same, but couldn't say for sure. Ask Dal.
Old Feb 19, 2003 | 04:22 PM
RamAir95TA's Avatar
Yes, they are the same. Only the rear O2s are not interchangeable (square connector versus flat connector).
http://www.worldisround.com/photos/375/153.jpg
Old Feb 20, 2003 | 07:15 AM
Cool...Thanks guys...Thats exactly what I wanted to hear!
