hesitation
Old Feb 13, 2003 | 03:55 PM
lt4 fd's Avatar
hesitation
Today I floored it in 2nd gear at about 1500-1700 rpm and it popped loudly from either where my gutted cat is or under the hood and didnt accelerate and I let off immediately. I also noticed sometimes at below 2000 it hesitates to go like it will accelerate some and then kick in about a half second later, I dont know if its the opti doing this but I know mine is bad and it usually just lurches and bucks. Seems to be more prominant now that I put different oil and filter in but I think if it was an oiling prolblem that kept the engine from accelerating I would have serious and very noticable problems. Anything here that sounds bad or a problem you know the solution too?
Old Feb 13, 2003 | 04:00 PM
Gripenfelter's Avatar
Check for leaks in the EGR system.
Vacuum lines and EGR pump.
Old Feb 13, 2003 | 04:38 PM
lt4 fd's Avatar
Isnt that all behind the engine? Didnt know the egr could cause all that. Ill check it out.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
