best place to buy 396 stroker kit?
Old Feb 13, 2003 | 02:17 PM
94droptopz's Avatar
wheres the best place to buy a fully forged (crank,pistons,rods) 396 stroker kit? im looking to get some suggestions from all the guys here running them. in your opinion , whats the best kit (eagle,scat,callies......) im looking to buy within the next week or so , so all your opinions help. thanks guys
Rob
Old Feb 13, 2003 | 02:34 PM
teke184's Avatar
nu-tek
i think it's www.nu-tekmotorsports.com
Old Feb 13, 2003 | 02:42 PM
Gripenfelter's Avatar
I second Nu-tek.
Old Feb 13, 2003 | 03:06 PM
94droptopz's Avatar
so both of you would suggest the callies kit over the eagle or scat? is there an advantage going with a 5.850 rod over a 6"? i see the 5.850's are a little more expensive. just wondering
Old Feb 13, 2003 | 04:09 PM
I have a SCAT crank and I had a local guy build my motor. He did a fantastic job but if I had to do it over I would have just ordered a pre-built one from Nu-Tek to avoid the headaches.
Old Feb 13, 2003 | 04:25 PM
BlkScreaminMach's Avatar
I 3rd Nu-tek
Nu-tek ROCKS, except no less, they got everything you need, even if you want to do it yourself.
WHen you change rod size it has to do with oil control, that the pistion with the 5.XX length has more space with the rings and th floating wrist piston is moved. Its useually preferred over the 6" rod, but you will be fine with the 6".
I learned this when i went to a local shop with nu-tek's list and now the local guy told me all about why i should go with the 5.75 rod vs. the 6" ones. But otherwise everything is solid.
Old Feb 13, 2003 | 04:39 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
combo motorsports
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
blue89iroc
Jul 18, 2002 03:35 PM
