Aftrmarket Starter Install Question
Old Feb 13, 2003 | 07:17 AM
brandboZ28's Avatar
Those of you with aftermarket starters, was it a direct bolt up or do you have to cut and bend things. I am looking at either the CVR from Jegs or the Powermaster from Summit. As of now, I am leaning towards the Powermaster from what little I have heard about both of them. Anyways, please let me know if modifacations are in order to get these to fit. Thanks.
Bo
Old Feb 13, 2003 | 09:14 AM
Mad4SMP's Avatar
I just installed a Summit Racing Starter #SUM-820323. Its similar to the CVR #5323. In fact, it might be the same starter. As for the install, it was a direct bolt-in and I did not have to use the provided shims.
--Mike
Old Feb 13, 2003 | 09:19 AM
brandboZ28's Avatar
Sweet, Thanks Mike. I just looked at it and it looks pretty good. Is anyone else using any different brands? If so, how are they? Thanks again Mike.
Bo
Old Feb 13, 2003 | 01:23 PM
I have the CVR, and there was a minor interference with the edge of the oil pan. The corner of the mounting block on the CVR was beveled to clear the pan, but for some reason it wasn't quite enough. A quick hit with a grinder solved the problem. Other than that, it was a direct bolt-in... no shims, good ring gear engagement.
Old Feb 13, 2003 | 05:42 PM
brandboZ28's Avatar
Thumbs up
Fred, your car is incredible. It is truley a work of art. Looking into the starter right now. Thanks for the reply.
Bo
Old Feb 13, 2003 | 07:32 PM
dave1w41's Avatar
I put the CVR on my Dad's Chevrolet Express after the stock starter crapped out. It fit with slight trimming of the stock Torque Converter dust cover. Now it sounds like a race car when you start it. Has been fine for over a year.
The CVR is about as good a quality piece as you can get for that money.
Old Mar 6, 2003 | 01:37 PM
KWKSLVR's Avatar
S.E. Region Moderator
My CVR came in today, this sucker is HUGE . Did you guys have to drop the y-pipe to get this thing in? I've got an M6 BTW.
Oncomingstorm22
Jan 22, 2015 07:15 PM
Jason Short
Jan 19, 2015 06:34 PM
Jeff1904
Jan 3, 2015 12:00 AM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 18, 2014 12:57 PM
