How much boost do you go up from 6# with a power pipe/solid intake tube???
Old Feb 13, 2003 | 03:36 AM
96 WS6's Avatar
Just like the subject says. The idea of picking one up is floating around in my head.
Old Feb 13, 2003 | 08:49 AM
IDOXLR8's Avatar
Most people usually pick up 2lbs - 3lbs of boost.
Old Feb 13, 2003 | 04:03 PM
96 WS6's Avatar
damn from 6#-8# just from that!!!!
Old Feb 13, 2003 | 07:46 PM
mongse_1's Avatar
Yep. If you've ever seen how much the rubber elbows suck in under boost, you'd definitely believe it.
Old Feb 13, 2003 | 09:03 PM
Blown 96 WS-6's Avatar
That is an accurate number. I just pulled out my last dyno sheets and I showed 8.38 psi of boost at 5900 rpms and I am running the stock 6 psi pulleys with the Brad Brand tube.
Old Feb 13, 2003 | 09:55 PM
aram's Avatar
I need to go order one of those..
Old Feb 14, 2003 | 03:18 PM
Highlander's Avatar
Where can you order one????
Old Feb 14, 2003 | 04:15 PM
1st and goal's Avatar
I'm not sure where to get a Brad Brand intake tube but Mufflex sells one or you could always fab up on yourself.
I bought some mandrel bent tubing from www.mandrelbending.com and fabbed up this
www.geocities.com/marcs94z28/4inchinlettube.html
Brett (SCZ28) fabbed up his using PVC tubing from Home depot.
Marc
Old Feb 14, 2003 | 11:28 PM
Highlander's Avatar
What thickness of the pipe????
I should buy then 5 90º elbows and then solder it as needed...
Old Feb 14, 2003 | 11:55 PM
Camaro_SS/R's Avatar
It's cheaper if you make your own.
I bought the Brad Brand tube from Atlanta Chassis Dyno. Give them a call they should have them. It is a good quality piece.
www.acdyno.com
1855 Buford Highway, Suite C,
Duluth, Georgia, 30097
Phone: (770) 623-9789 Fax: (770) 623-8077
cheers
Old Feb 15, 2003 | 12:35 AM
Highlander's Avatar
I thought they were out of them, that was why I was inquiring about custom building... hmm..
anybody have one to sell??
Old Feb 15, 2003 | 04:10 AM
aram's Avatar
Marc
That's for the ATI. The brad brand is for the vortech I believe.. there are a lot of somewhat odd size bends in the vortech one which would make it more difficult to make yourself.. but I have a welder and some free time, so I might attempt to make one myself.
Old Feb 15, 2003 | 10:20 AM
I'm not sure what the size of the intake hole is at the impeller on a Vortech but ATI's is 4" and then you have to reduce it to 3½" if you're going to run the MAF on the intake side, I'm running a Speed Pro (F.A.S.T) system so it's 4" all the way for me
Marc
Old Feb 16, 2003 | 09:54 AM
EDS Z28's Avatar
Marc,
Did you retain a small portion of the orange flex hose near the blower? Nice air filter, do you have the part number for that? I am going to get off my *** and finally make one of these.
Ed
Old Feb 16, 2003 | 03:04 PM
Ed,
Yup, still got the orange hose but it only makes the quick hard turn and then it's solid tube all the way.
If the spirit moves me when it's warmer out (freaking cold out here in New England) I'm going to try and get rid of the orange hose...again it's a time item and I got larger issues in life right now
The K&N part number for the filter is RE-0860
Here is a link to Brett's (SCZ28) as he made a homeade intake out of PVC http://members.aol.com/eplbrc/Finished_Intercooler
Marc
