remove cat??
Old Feb 13, 2003 | 02:19 AM
MikeStank's Avatar
remove cat??
I won't neen emmissions this year, and I'm planning on getting new headers and a high flow when the time comes. For the time being is it safe for me to remove my cat with the exhaust i have listed in sig. I'd just have a straight pipe. I have some small holes right infront of the cat in an area that would be very difficult to fix that's the main reason I need a new one.
How much louder will my car be? and will it run fine with the borla at full open or will I need to close the borla up a bit to get some back pressure.
Old Feb 13, 2003 | 06:00 AM
Thebeast431's Avatar
All OBD-I vehicles don't have to modify anything, but if you are OBD-2 you need the O2 simulator. It will make you exhaust louder, not exactly deeper though, just louder. Free up a few hp also. I would reccomend getting a cut out instead. You would get even more hp, still street legal, when capped, and cost you the same as a test pipe.
Travis
Old Feb 13, 2003 | 08:01 AM
DR.ZED's Avatar
Talking
The only downfall is that you'll be a bit stinky out the back, and you may see a bit more smoke on WOT runs.
Since when has that ever been a problem?
I have a hollowed cat, and recently went to an offroad pipe. The ORP is a much cleaner, less raspy and annoying sound as the gutted cat.
You'll love it.
With my pistons, and "mild" cam with the Mac setup and B&B tri flow, it sounds nasty.
My girl was following me one night, and I hammered it on the highway, she said it sounded like thunder, and then she had a car-gasm.
That should be the only testiment to doing this.
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
