bad battery?
Old Feb 12, 2003 | 08:26 PM
DAC350's Avatar
bad battery?
I turn the key and all I hear is loud repetitive clicking. The headlights are slow to come up and the dash lights are dim. Time for a new battery, or could it be another problem? Thanks.
Old Feb 12, 2003 | 08:56 PM
Battery or poor connection to it.
Old Feb 12, 2003 | 08:58 PM
DAC350's Avatar
What can bad ground wires cause?
Old Feb 12, 2003 | 10:35 PM
If you are referring to the ground wire off the battery, it is no less important. Both cables must be well connected to form a complete circuit. Any other grounds must be in good shape if your car is going to operate like it should.
Old Feb 12, 2003 | 11:41 PM
12sec97Z28's Avatar
Battery! Just had the same problem. It would read full voltage under no strain, but under load, it would just shut off all electronics in my car. If i opened the door, there was a clicking noise from what sounded to be under the passenger side dash, and the alarm light on the dash would be blinking very fast. I thought it was a bad relay or ground, so i made the mistake of taking it to the dealership. They wanted 113 bucks for a delco battery so i told them to shove it and got an optima red top for 110. Sounds like a much better deal to me.
nosliw
Apr 26, 2015 02:13 PM
TEG99SS
Apr 11, 2015 10:08 PM
eanhl2004
Apr 4, 2015 12:01 PM
nosliw
Feb 7, 2015 01:30 PM
