Fuelpump ?
Old Feb 12, 2003 | 08:04 PM
1993lt1's Avatar
Fuelpump ?
I have a 355 home ported heads.224 / 236 cam 9 to 1 comp. D1 ati twin hi flow coolers.15# boost.100 shot of no2.I am going to buy 72# or 83# injecters. Is single in line walbaro pump with stock lines going to work.
Old Feb 12, 2003 | 08:29 PM
Brandy's Avatar
Not if you plan on making any real power. A D-1 with a bottle should easily make 700rwhp, beyond what a single Aeromotive A1000 pump will support. I think you are going to be in Weldon 2035 territory with atleast -8 feed and -6 return lines.
Old Feb 12, 2003 | 08:38 PM
97TA-WS6-Con's Avatar
Re: Fuelpump ?
I believe the stock lines will work but the pump is not enough.
I went with a Racetronics dual in-tank pump. I have an almost identical set up although I have a 383 and no nitrous
Old Feb 12, 2003 | 09:51 PM
LT4ultraZ's Avatar
I have a HOT cam 355 home ported heads ATI D1sc 12lb and i am about to put a 75HP wet shot of nitrous on it.The 42LB injectors seem to be working fine so far they are at 78% DS. The stock fuel pump with the ATI inline on the other hand is running out of steem at WOT. I was told by a reliable sorce that if i changed my intank pump to a 340 I will be good to go. 467 HP 435TQ before nitrous so far
Old Feb 13, 2003 | 12:36 AM
96speed's Avatar
Email www.racetronix.com. AWESOME service, very knowledgable with fuel systems. You won't be dissappointed.
Ryan
Old Feb 13, 2003 | 08:47 AM
IDOXLR8's Avatar
I would recommend doing a twin intank pump setup. It will supply all the fuel you need through the stock lines. Have you dynoed your car without nitrous?? In order to run the 72 lbers or 83 lbers you are going to either need an Acceleronics impedance convertor or any aftermarket computer.
Old Feb 13, 2003 | 05:20 PM
1993lt1's Avatar
I am going to run a FAST EMU. Maybe 340 intank with a bost A pump. or 340 in tank and ati in line. I already have 340 in tank and ati inline.has any one tried this.
Old Feb 14, 2003 | 04:57 PM
1993lt1's Avatar
How about R Krause I thing he is running single in tank. At super hi HP. blower and no2.
Old Mar 14, 2003 | 11:11 PM
Racetronix's Avatar
Post
If you are going to run properly sized injectors so that you can avoid using a FMU then a single HP or dual HP in-tank system would be a good idea.
Keep in mind that ATI's in-line pump is a T-Rex by Airtex. Its flow rating is apx. 200L/Hr. The Walbro GSL392 is a high-pressure 255L/Hr pump which is physically smaller and quieter.
The ATI in-line system comes with a generic non-weatherproof semi-finished wiring harness.
Racetronix sells the Walbro GSL392 fuel pump along with various PnP weatherproof application-specific wiring harnesses for the same or less money.
Jack
Racetronix
(PS not Racetronics)
Old Mar 15, 2003 | 01:04 AM
zturbo's Avatar
I think for what you are wanting to do 15# and 100 shot I would not run a boosta pump. I would rather go overkill on my fuel system rather than hoping that I can get by cheap. Have you thought about possibly running your fuel system for your motor/blower on the stock setup and the nitrous using a secondary fuel system possibly with a small tank in the front and put some good fuel in it? For the power that you are going to get close to I would take a look at more than stock lines, but again I go overkill on fuel cause a fuel system is cheaper than a motor.
Steven
Old Mar 15, 2003 | 08:50 AM
rskrause's Avatar
Moderator
My setup for the last two years was a Bosch 255lph intank, stock lines, regulator, and rails. The key to making it work was the Boost-a-Pump and the injectors. The BaP increases voltage at the pump under boost. I cranked mine up to the max to give 17v. I believe output increases as the square root of the increased voltage? That would mean the pump would be flowing the equivalent of ~300lph at 17v. Since I was using multiple injectors (50lb "main" plus 3x92lb in the Superfueler) my injectors were equivalent of ~85lb injectors and I was able to stick with stock fuel pressure. This supported 733rwhp.
I am upping the ante this year and am going to a bigger fuel system, but I am not convinced that the current system wouldn't have supported a bit more. A key thing with a big fuel system on an LT1 is incorporating some method for varying pump output to demand. If the car is used on the street, you don't want a huge amount of fuel flowing through the system when you are just driving around. It heats up the fuel and may overwhelm the stock regulator. This years setup will use two external pumps, the first pump will use a variable voltage controller similar to the BaP and the second will be boost activated. I am going to feed both rails separately but stcik with stock rails. It may be overkill, but it also support the next step, whatever that may be as it should be good for ~1500hp and the new setup will be in the 1,000hp range.
You could certainly use a similar system to mine with 70-80lb injectors, as your combo seems very similar to my setup. Good luck.
ps: I have also heard good things about Racetronix and strongly considered their dual in-tank system. I think it would have worked fine but wanted an external system for ease of service, etc.
Rich Krause
Old Mar 15, 2003 | 09:43 AM
EDS Z28's Avatar
Wow, your setup is almost exactly like mine. What tranny are you running an auto or manual? My entire fuel system has been uprgraded and the wide-band showed the engine is running rich just about everywhere (better than lean, ha). It is running with stock programming except the injector constant has been changed to compensate for the 42's. I am seeing around 10 pounds of boost from the P600B, although a solid intake pipe was installed recently and I haven't had a chance to look at the gauge.
autoxr166
Sep 25, 2015 04:21 PM
sbca96
12
Feb 14, 2013 10:17 AM
Steel185
Apr 2, 2009 12:41 PM
Danny McAdams
Sep 19, 2007 12:58 AM
BlackScreaminMachine
Sep 26, 2005 12:21 AM
