GM 1.6 Roller Rockers?????????
Old Feb 12, 2003 | 06:28 PM
Muskys SS's Avatar
Are the gm performance 1.6 roller rockers the same for years 1987 through to 1997.
I'm looking at purchasing some and the guy says that they fit 87 and up???
Is this true?????
Thanks in advance
Old Feb 12, 2003 | 08:16 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
I think TPI rockers fit LT1's...
TTT for ya
Old Feb 12, 2003 | 08:32 PM
FastZinTennessee's Avatar
From what I've heared the guy that you talked to was right.
John
Old Feb 12, 2003 | 08:35 PM
bad96firechikin's Avatar
Built a '89 TPI motor with dad once....used the GMPP 1.6 RRs....no prob.
Old Feb 12, 2003 | 09:02 PM
Dr.Mudge's Avatar
They are regular old SBC stuff, so those will work.
Old Feb 12, 2003 | 10:23 PM
Muskys SS's Avatar
Cool
Thanx for the replies
93Z4ME's Avatar
I believe that they will work, the main issue being that they are designed for clearance for centerbolt style valve covers, and they are "self aligning". (if they are self aligning, you will need to install a LT4 knock module)
If they are not self aligning then you will need guide plates and hardened push rods.
With any higher ratio rocker installation, new springs and retainers are recomended and you should always check all installed clerances (make sure there is no coil bind etc..)
Old Feb 12, 2003 | 10:36 PM
NiteRider's Avatar
What do you need rockers for shaun? Got some mods in mind? Huh? Huh? Huh?? Spill your beans!
Old Feb 12, 2003 | 11:22 PM
drop top steve's Avatar
How about 1955 and up
Old Feb 13, 2003 | 06:57 AM
94 NO TOP Z's Avatar
Yeah.. that sounds right. I forget the exact year but, it was mid-80's when GM went to self-aligning rockers. That is the key. Those are the ones I have.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
