air pump???
Old Feb 12, 2003 | 11:47 AM
qwick_trip's Avatar
Question air pump???
ok i just put headers on and want to get rid of the air pump1 how do i do that? and will the ses light come on? does the light make any differance in performance like the check engine light does or is it just annoying? thanks
Old Feb 12, 2003 | 11:56 AM
1msfyter's Avatar
What year is your car 94-95 obd1 will not set off the SES light obd2 WILL and you will need to have it programed out.
Old Feb 12, 2003 | 11:58 AM
qwick_trip's Avatar
it's a 95
Old Feb 12, 2003 | 12:17 PM
1msfyter's Avatar
this? before and after
www.bealer.org/valvecover.jpg
www.bealer.org/plug.jpg
Old Feb 12, 2003 | 09:33 PM
qwick_trip's Avatar
i can't get those links to work. how do i get rid of the air pump and air tubes? please!!!!!!!!!!!!!! thanks
Old Feb 12, 2003 | 09:37 PM
stik6shift93's Avatar
Go to www.projecttransam.com they have a write up on it there. It wont set an engine ses unless you have obd2 on your 95, it won't be obd2 on your 95 unless its from california. Good luck
Old Feb 12, 2003 | 09:39 PM
qwick_trip's Avatar
ok thanks, oh how do i tell if my car has an obd1 or obd2?
Old Feb 12, 2003 | 09:42 PM
Buttercup's Avatar
The best way to determine what OBD system you have is to simply look at the emissions sticker under the hood. It's up on the radiator support and if you look carefully it will state whether the car is OBDI or OBDII
Old Feb 12, 2003 | 09:48 PM
qwick_trip's Avatar
ok thanks
Old Feb 12, 2003 | 09:53 PM
rotoruter2001's Avatar
i have an obd2 and my ses doesnt come on.
Old Feb 12, 2003 | 10:42 PM
You're just lucky.
Not true. All 1995 LT1s were OBDI.
Old Feb 12, 2003 | 10:45 PM
94_formula's Avatar
what are teh advantages of removing the air pump
Old Feb 12, 2003 | 11:09 PM
The only real reason to remove it is if you don't have cats. Even then, it is only a small weight savings, nothing more. It supplies extra air to the cats to allow them to heat faster during the first few minutes of engine operation. Another benefit is that it helps to protect the cats from the rich fuel mixture when the engine is cold, thereby prolonging their life and resistance to clogging.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
