Help, What Did I Break In The Motor!!!!
Old Feb 10, 2003 | 01:23 AM
BRIAN93Z28's Avatar
I just raced my buddy in his really quick mustang like 7 times in a row, all high speed races (145+)On the last race I thought I was in drive and when it was time to shift to OD, i shifted, but hit nuetral because i had mistakenly already been in OD, and smacked the rev-limiter a few times. After I slowed back down I realized i had a REAL loud tapping noise coming from the motor. Almost sounded like a really loud lifter tick. Also, was thinking it might be a bent pushrod or two. I'll pull the pushrods out tomorrow and check them out. The car drives and idles fine, no smoke, no leakin oil or coolant. Just the noise....what do you guys think I could have done???? I hope its nothing major. Also, do you think hooking it up to Auto-tap could help diagnose it? My buddy has it and I thought we would hook it up and see whats going on. Any help would be GREATLY appreciated.
Brian
Old Feb 10, 2003 | 01:47 AM
Ferocity02's Avatar
Sounds like it could be a rod. My friends old van broke a push rod and it acted just like urs, except it always smoked
Old Feb 10, 2003 | 09:12 AM
stik6shift98's Avatar
usually when u bang the limiter u bent some rods.... its almost 100% u need to replace them...and get chrome moly this time
Old Feb 10, 2003 | 09:30 AM
PhantomTA's Avatar
Moderator
please specify Push rods when you say bent rods.. A connecting rod is what is normally refered to as a "Rod"
you most like had some valve float and had some valves hit the pistsons.
you could have done one or multipul things.
Bent valve(s)
bent pushrod(s)
notched a piston(s)
colasped a lifter(s)
if the SES light doesnt flash it means you do not have any crazy missfires but it can still be bad.. i bet some valves and like 7 pusrods and it ran almost normal.
BTW, this is what happens when you shift an auto that does not need to be shifted manually.
Old Feb 10, 2003 | 09:32 AM
BRIAN93Z28's Avatar
Phantom...how do i check if i collapsed a lifter or bent a valve? Just have to take them out and look??
Old Feb 10, 2003 | 12:36 PM
take off the valve covers and look
Old Feb 10, 2003 | 01:59 PM
afterimage ss's Avatar
LOL @ phanton ta
Old Feb 10, 2003 | 06:57 PM
did u get it fixed yet?
Victor Lamb
Aug 26, 2017 02:52 PM
armedtrigger
Feb 24, 2015 08:30 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
