What are the components that make up the "BOTTOM END"
Old Feb 10, 2003 | 12:42 AM
Megalis's Avatar
Eventually I will be very happy When my car reaches the 425hp-450hp mark. I really don't need/want any more than that. I will not be using force induction of any kind. I will however in addition to what I already have will be adding, headers, 58mm Throttle body, manifold..etc. I want to make sure the bottom end holds up for those kinds of numbers. And even if it does, I would still like to know what all makes up the bottom end so I can upgrade it anyway. Thanks
BTW I have a 94Z
Old Feb 10, 2003 | 12:49 AM
96z's Avatar
96z
When most people talk of the bottom end they mean the shortblock, or rods, crank, pistons, bearings, etc. I guess you could even include the cam, timing chain. A simple way of putting it would mean everything below the heads.
Old Feb 10, 2003 | 01:18 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
and oil pump.. oil pan... most people upgrade their crank, rods, and pistons.
Thought if your goals are 425hp... you can do that w/ the bottom end already in your car.. Just need a good set P&P'd heads and a cam.
Old Feb 10, 2003 | 11:07 PM
Megalis's Avatar
Thanks guys, I am getting the idea. I really was kinda clueless, but I know much better what is needed and what direction to take.
DirtyDaveW
Dec 1, 2016 05:37 PM
CARiD
Jan 27, 2015 06:27 AM
sscott
Jan 17, 2015 04:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
Bando
Sep 2, 2002 07:59 PM
