O2 Sensors OBDII to OBDI conversion
Old Feb 9, 2003 | 08:26 PM
SnkEatr's Avatar
Since I am making the switch from OBDII to OBDI. can the OBDII O2 sensors be used with the OBDI PCM?
Old Feb 9, 2003 | 08:27 PM
bad96firechikin's Avatar
Ya. You're gonna be A-OK.
Old Feb 9, 2003 | 09:49 PM
shocktrp's Avatar
The only difference in the sensors is the plug. If you are using the OBD-II wiring harness, you use OBD-II sensors.
Old Feb 9, 2003 | 09:53 PM
madwolf's Avatar
Yep, as useless as this third confirmation is, you'll be fine...
Old Feb 9, 2003 | 09:56 PM
SnkEatr's Avatar
Thanks all. I thought so but I saw a post.... that said some thing like.... Oh hell forget it if it works then fuggit.
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
SergheiS
Jul 5, 2015 03:27 AM
cmdeshon
Jan 4, 2015 11:15 AM
