shaking in the car
Old Feb 9, 2003 | 05:45 PM
Dmx4ever3's Avatar
Angry shaking in the car
when i drive like 80 or above my car starts to shake and get worst and worst as i go faster can't even go like 110 i got new engine mounts i have the better trans mount but i think my throw out bearing is bad i dunno what it could be tires r good email me or rely thanks dmx4ever3@aol.com
Old Feb 9, 2003 | 06:02 PM
94_formula's Avatar
drive shaft? maybe u-joints?
Old Feb 9, 2003 | 06:06 PM
stik6shift93's Avatar
Did you upgrade to poly mounts? if so there's your prob they let a lot more vibration threw.
Old Feb 9, 2003 | 10:03 PM
Fear The Z's Avatar
Re: shaking in the car
Ive heard that all camaros with stock DS (steel) is unbalanced...Mine does the same thing about 85. They claim you can put an aluminum DS and it will eliminate it...Im trying to save up money and we shall see if it works...
Old Feb 14, 2003 | 08:24 PM
FormulaL03's Avatar
tornando is the problem!
It must be the $80- tin foil. You know the piece of foil is very important to that engine. If you put it in wrong, that could cause the engine to possibly seize. hahaha will, you are the biggest numbnut ever! seriously a piece of foil causing car vibration? what planet r u from? o yeah planet cheryl lol anyway that would be caused by like wheel balancing, proper alignment and o yeah your drivetrain. I doubt your engine mounts would cause your car to vibrate past 80mph think about it. mounts are meant to absorb torque.. and no offense but after 4th gear, ur all horesepower, not torque... your 4th gear is probally like 1.2 to 1 if that.. I doubt that would cause vibrations at high speeds.. I recommend taking it to a shop not santillies since they anally rape you every time you go there. (gullable) good luck
Not justin,
Old Feb 14, 2003 | 10:04 PM
Hyperspeed97z28's Avatar
its your STEEL driveshaft, get a "1le" or a "ls1" driveshaft, that outta fix your problems...
Old Feb 15, 2003 | 02:26 AM
Dmx4ever3's Avatar
i IM getting a driveshaft out a 98 Camaro aluminum Ds we will see if it works
Old Feb 15, 2003 | 02:29 AM
Dmx4ever3's Avatar
used 99 Camaro Z28 LS1 aluminum driveshaft complete my bad its cost 187 and 198.05 shipped
Old Feb 15, 2003 | 02:50 AM
Fear The Z's Avatar
Guess it didnt work???
Old Feb 15, 2003 | 03:01 AM
Dmx4ever3's Avatar
i don't know it if worked yet i just buyed it its being shipped now then i will need to get it installed
Old Feb 24, 2003 | 01:32 AM
Dmx4ever3's Avatar
i think it fixed my problem O and 1 of my u joints i think were bad but it drive smoothly now
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
Bando
Oct 7, 2002 07:36 PM
