100 shot hurting M6 tranny?
Old Feb 9, 2003 | 09:56 AM
therealmagyver's Avatar
Will my tranny go bad on a 100 shot? Not going to spray often mostly for the track. When should I have the rpm switch cut off...at my switch point or right before it? Will this help the tranny at all?
Old Feb 9, 2003 | 10:48 AM
KTamez's Avatar
The tranny itself *should* be fine, however you can probably kiss the clutch good bye. The STock LS1 Clutch isn't even enough for a STock motor if you race the car much at the track.
Old Feb 9, 2003 | 06:09 PM
stik6shift98's Avatar
it will be fine....clutch will go bye bye.....
and dont spray out of the hole or your rear end will go too....
Old Feb 9, 2003 | 06:11 PM
stik6shift00's Avatar
no just dont beat the crap out of it.....i think youll be ok..it also depends on miles
Old Feb 9, 2003 | 06:18 PM
stik6shift93's Avatar
It'll take quite a bit more than a 100 shot to hurt an m6, the clutch is what I'd be worried about.
Old Feb 9, 2003 | 06:53 PM
HiYaPerri's Avatar
You will be fine...dont be such a p***y..JKJKJK
Old Feb 9, 2003 | 06:58 PM
Aiight so I have to worry about my clutch. Will it last me a few times at the track? I am spraying on with WOT and and between 3000 and 5800. Do you think I will be okay? I am getting drags either from nitto or kuhmo to launch better. BTW what clutch is relatively better than the stock, but not super expensive?
Old Feb 9, 2003 | 07:29 PM
ttt!
Old Feb 9, 2003 | 11:47 PM
tireburnin's Avatar
Are SLP clutches up to the task? Will it be short lived?
Old Feb 10, 2003 | 12:50 PM
say good bye to slp clutch...
get star spec stage 3 ceramic like me
slimdawson
Aug 25, 2002 10:10 PM
MBonZ28
Jul 30, 2002 11:42 AM
Black Sunshine/ 00SS
Jul 24, 2002 08:57 AM
MBonZ28
Jul 24, 2002 02:35 AM
