Engine Temperature
Old Feb 8, 2003 | 08:58 PM
thelategreatz28's Avatar
Engine Temperature
Hey when I drive, and idle for like less than 5 minutes, the needle on the guage goes up until RIGHT below the red, and then cools down when the fans kick in. When I drive on as long straighaway it slowly cools down. Is this normal?
Old Feb 8, 2003 | 09:23 PM
TMDZ28's Avatar
mine did the same thing...should be normal
Old Feb 8, 2003 | 09:47 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
NO not normal... you got a sticking thermo.... get it replaced before you get a sludge monster on your hands
Old Feb 8, 2003 | 09:53 PM
c5formetoo's Avatar
or your fan relays are going bad.if you have the dual fans 1 comes on first then the other at a higher temp.your relay for the first fan may have died.mine did this and it was the main fan relay.
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Rich_z28
May 6, 2003 08:38 PM
