A4 and TORQUE CONVERTER PROBLEMS
Old Feb 8, 2003 | 07:36 PM
VINCELEE123's Avatar
ok, I forgot to put transmission fluid in the TQ converter before install and lock it in to the tranny before bolting on to flywheel,
we started the car and put it in drive and it wont move,
what damage did i do? did i burn the converter up or did
destroy one of the pumps? just need the truth
Old Feb 8, 2003 | 07:54 PM
funina91ss's Avatar
my buddy did this once and messed up the trans and they had to fix it but after getting it back in the converted cracked it was a vig. i am not sure on what damaged you may of caused.
Old Feb 8, 2003 | 09:00 PM
ttt
ttt
Old Feb 8, 2003 | 09:03 PM
c5formetoo's Avatar
i dont think you should have hurt it.did you add fluid and check the level.you need to add the fluid with it running in park.converter should hold more than 4 quarts
Old Feb 8, 2003 | 09:12 PM
ok
i havnt pulled it off and locked the converter in place yet,
so ive put about 10 quarts of fluid in all ready,
the only thing i was worried about is even if the tq converter
wasnt lock in shoudnt the pump started movin the fluid?(the fluid level didnt change on dip stick)
vince
Old Feb 8, 2003 | 09:19 PM
c5formetoo's Avatar
it will not pump if its not locked in.put it back together and let us know.should be fine.if you hurt anything it would be the front pump and that is easy to change.
Old Feb 8, 2003 | 09:49 PM
Thumbs up thanks
thanks!!
vince
Old Feb 8, 2003 | 09:59 PM
c5formetoo's Avatar
good luck post your results
Old Feb 10, 2003 | 08:46 PM
problems
ok i pulled the tranny out and tried to put the converter on and it didnt click, so im guessing maybe the pump is broke. any ideas?
how big of a deal is it to change the front pump? also i noticed the tranny was leaking a strawberry milkshake color from the converter only, everything else was red, maybe this was grease from the pump?
any ideas would help.
vince
problems
vince
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
