Kenwood Powered Subwoofer hook up questions.
Old Feb 8, 2003 | 04:02 PM
Smokn '94 Z's Avatar
Question Kenwood Powered Subwoofer hook up questions.
Hello. My friend gave me a Kenwood Powered Subwoofer tube style he had lying around. Anyway I can't seem to get the thing hooked up right or not powered up for some reason. I have a pic of the hook ups on the Tube that I can e-mail to who ever can possibly help. It is self amped. I hooked up the power supply & hooked up the ground. Then I got a a line output converter hooked up along with RCV cables. Then I ran the speaker wire that comes from the output converter to the speakers. I then hooked up the line output converter to the Kenwood powered subwoofer. I have it hooked up the way I think is right. (This is where you come in) If you can help I can send you a pic of the Subwoofer's hook up panel. Thanks..
Old Feb 9, 2003 | 06:03 PM
stik6shift93's Avatar
Did you hook up the remote turn on wire? The amp usually have a remore turn, you just need a wire(that only gets power when the ignition is on) that runs to the amp and thats how the amp tells when to turn on and off.
Old Feb 9, 2003 | 06:06 PM
Question
Would that wire go to the P-Conn connection in the pic?
Old Feb 9, 2003 | 08:13 PM
stik6shift98's Avatar
send me a pic....
remote will usually be right next to ground and 12 volt
it will be indicated as REMOTE or RMT
Old Feb 9, 2003 | 08:48 PM
Thumbs up
Originally posted by stik6shift98
send me a pic....
Here is the pic..
http://www.z28.com/forums/attachment.php?s=&postid=3784
Old Mar 19, 2003 | 11:13 AM
MeefZ28's Avatar
I'm having the same problem- I see on the amp where the RMT wire goes, but where do I run the other side???
I know I need to run it to a wire or fuse that is powered only when the ignition is on, but I need more specific instructions on how to do this.
Some have said run the wire to the fuse panel to one of the fuses, but I don't know how i should connect it properly. Step-by-step instructions would be great. Thanks,
J
raroz28
Mar 10, 2015 11:18 AM
Ryabut98
Sep 3, 2002 11:45 PM
themushine
Sep 3, 2002 10:02 AM
themushine
Sep 3, 2002 10:01 AM
