M6 Syncro/Tranny problems
Old Feb 7, 2003 | 06:14 PM
ChrisLS1Bird's Avatar
Hey guys. I'm going to be buying a fast car soon. The decision is down to either a Supra or an LS1 Formula/ Trans Am.
The goal is to run mid to low 11s at least. That's actually the short-term goal. I'll be looking for 10's eventually.
The transmission will be an M6 with either car. I know the A4 in the f-bod would net me better ETs on the drag strip..but I like to shift gears myself and I don't do most of my racing on the drag strip.
If I go with the LS1 (which is where my heart is), I would install a turbo setup and go for around 500 rwhp. With my old Formula, I had problems with gears grinding and popping out. The syncros wore down pretty quickly and easily, and that car wasn't making that much power. I was told that the syncros were down-graded from the LT1 tranny style to a paper-type version for the LS1.
If I buy an LS1, can I have 500 rwhp and an M6 tranny that works? If the stock parts won't work, is there a specific place that people have gone to build these trannys? When I had my Formula, I looked around but could not find anyone who would strengthen the tranny. This is an important criterion of my decision.
Old Feb 7, 2003 | 07:29 PM
stik6shift93's Avatar
I doubt you'll have problems with it, I've seen people push a lot more power threw a t-56 than that. You might want to upgrade the shift forks though, other than that it's a really solid trans.
Old Feb 7, 2003 | 11:04 PM
You've seen people push that power through a T-56 in an LS1 with no problems? Or, are you talking about Vipers and LT1s? The tranny really let go on me last time.
It's a Tremec in the LS1, not Borg-Warner, right?
Old Feb 7, 2003 | 11:32 PM
I don't believe they switched the tranny until 01-02 so if you have a 98 you should be fine. To ansewer your other question yes I've seen quite a few ls1 push threw that much power with out probs. The 01-02s are the ones you have to worry about though they are still pretty strong.
Old Feb 8, 2003 | 09:10 AM
PhantomTA's Avatar
Moderator
in 98 they changed the syncros to a cheaper version..
and 99 they went to mexico and became tremecs
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
