Lt1 Tb
Old Feb 6, 2003 | 05:11 PM
Mogulskierk2's Avatar
Lt1 Tb
Hey all, I need some help.. I have a chance to pick up a LT-1 throttle body, with tranny for around $500, I was wondering what these were found in, if it's worth buying to build up, and if i got the casting numbers off the block, if anyone could decode them for me...
Thanks in advance
Old Feb 6, 2003 | 05:21 PM
n2ceptor's Avatar
Block castings # are all the same on the LT1 (2 bolt & 4 bolt)... Just look for the numbers"327" on the side of the block... The only way to tell if you have a 4 bolt is to drop the pan.....
If it has Alum heads then its from a corvette/4-gen body.. Cast heads are from Impalas....
Then there is the LT4....It came out in '96...
watch out for the L99(265 cid) Its like a baby lt1... NoGood.
93z Will
Old Feb 7, 2003 | 05:06 PM
Thanks for the help.. but how do i know if it's a L99??
Is the LT4 ok to build up.. what's the diff, between a LT4 AND A LT1??? I'm assuming just the upper end (ie heads and intake) but the block is the same right?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
