squeaky clutch??
Old Feb 6, 2003 | 09:18 AM
z28marine's Avatar
squeaky clutch??
Whenever I push in my clutch, there is a squeaky sound coming out of the pedal. Im pretty sure its coming from the small cyclinder type thing up by the clutch pedal. Everytime i push in the pedal to shift gears i get this very anooying squeaking sound and its just so damn annoying....anyone have this problem or a wy to get rid of it. I tried a little WD40 on it...didnt work at all.
Old Feb 6, 2003 | 09:27 AM
GetaZforgetGT's Avatar
I have the same problem.
I haven't figured out a way to fix it yet.
Hopefully someone else has.
Old Feb 6, 2003 | 09:47 AM
Xride's Avatar
I have this problem too, its worse when its real cold outside.
Old Feb 6, 2003 | 05:57 PM
97_TA_WS6's Avatar
I had that same squeak to for awhile but it finally went away and hasn't been back since. Maybe a spring on the top of the pedal under the dash might need to be lubed.
Adam 1997 Trans Am WS6 M6 has Borla cat back,LT4 knock module,subframes,Hypertech PP+,Hypertech 160 Thermostat,Air foil,Mac Pulley,K&N filter,B&M Ripper Shifter,MSD 8.5MM wires,Energy Suspension Trans mount & Torque Mount,1LE Driveshaft,MBA Silver Shift **** with WS6 ingraved on it,SLP 21mm Rear Sway bar,Viper GTS-R Carbon Kevlar syncros in a rebuilt T-56, Throttle Body Bypass and SLP pressure plate/clutch.
Dallas, TX
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
