Quick hot cam question?
Old Feb 5, 2003 | 11:52 PM
DTBZ28's Avatar
I just ordered the hot cam kit for my 95Z and I was wondering if I could use the stock pushrods or will I have to purchase a different length pushrod?
Also the car has 80,000 miles should I replace the lifters and timing chain?
Old Feb 6, 2003 | 12:03 AM
chesee48's Avatar
i decided to get comp cam lifters however everyone says the stockers are way good enough...
Old Feb 6, 2003 | 12:09 AM
vodoo-chile's Avatar
I would check the pushrods by rolling them on a flat surface to make sure they are not bent. If they are alright, I would stick with those. As far as the timimg chain, I would go ahead and purchase a new stock set(chain and gears) for about $60. Safe insurance and with 80k (like mine) better to be safe than sorry. Good luck,
Kyle
Old Feb 6, 2003 | 12:10 AM
cef97ws6's Avatar
Your stock pushrods will most likely be OK. But since you will be adding 1.6 rockers with the kit you will want to double check your valvetrain alignment to be certain. I don't have any experience with the hot cam kit but I am assuming the rockers are self-aligning meaning guide plates are not required. If guide plates are required (not self aligning rockers)make sure you use hardened pushrods. Hope that helps
Old Feb 6, 2003 | 12:12 AM
I thought that all 95's came with harfened pushrods from the factory?
Kyle
Old Feb 6, 2003 | 12:26 AM
cef97ws6's Avatar
You are probably correct kyle I could not remember what years came with hardened pushrods and what didn't so I just wanted to be sure and cover the requirements.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
LT14LIFE
Feb 9, 2015 09:35 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
