problems with axle removal!!!!
Old Feb 5, 2003 | 08:28 PM
1994TransAm's Avatar
hi there,
i'm removing an rear end off a 94z.
we got the springs out, shocks,brakes, LCA's , bassiclyy everything except the damn panhard bar.
it wont budge at all.... i even used a impact on it!!!!
and also the sway bar nuts are fronzen and striped because they wont move, even with an impact!!!!!
how do i....
remove panhard
remove /break sway bar retainer bolts
please help me.
would an air chizzle work on the swaybar bolts?
Old Feb 5, 2003 | 08:36 PM
Z28ROC's Avatar
Use some liquid wrench. Then try it in a few hours or the next day. If the impact won't work, use a long breaker bar. Add a pipe extension to it if necessary. Lay down on your back and use your foot to break them loose. You can generate some serious heat with your leg.
Old Feb 5, 2003 | 09:13 PM
Formulized94's Avatar
I had to use a plasma cutter to remove my sway bar links. Just cut them babies in half. never had trouble with removing the pan hard rod.
DirtyDaveW
Dec 1, 2016 05:37 PM
4586
Jan 3, 2015 07:22 PM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
