Mysterious oil leak?????
Old Feb 5, 2003 | 07:16 PM
LALT1's Avatar
Put a new opti on last weak and now have a bad oil leak up fron below the intake. is this a common problem? What might it be? it has soaked the new opti so I must fix asap.
Old Feb 5, 2003 | 07:57 PM
BOWTYDE's Avatar
It is probly the seal between the opti and timing cover, you could have put the opti drive cam in the wrong hole in the opti and the opti dosen't have a tight seal with the cover. It also might be that, that seal is just trashed and you need a new timing cover.
Did the new opti fit flush on the mouting holes and not?
Old Feb 5, 2003 | 08:00 PM
LALT1's Avatar
Yea it was flush, but she has 172,000 miles on her. Seal I suppose, can it not be changed? without buying a new cover?
Old Feb 5, 2003 | 08:05 PM
DirtyDan's Avatar
It can be changed without replacing the cover. But I don't know if you can do it without removing the timing cover though. Call Jason Cromer for your parts he is way cheaper than your local dealer. I've done them twice now and it was pretty simple.
Dan
Old Feb 5, 2003 | 08:49 PM
Dan
You will just have to take the opti off again. No need to take the timing cover off. The seal is a couple of bucks. You can get one from your local auto supply if you want. With that many miles, you should have considered replacing the seal when the opti was off.
Oh, I would be sure that is where the leak was, first.
Old Feb 6, 2003 | 03:26 AM
94 TA TT2S's Avatar
Just go ahead and get a felpro timing cover kit.....and change all the seals while you are there.....No need to ask me why......lol Just better to make sure it is that seal....Jus t do them all to be sure ....it happened to me all along I thought it was the opti seal and it turned out to be wp seal.....so I had to tear it apart again and change it.....So save yourself so time and frustration.....get the kit....
Old Feb 6, 2003 | 07:45 AM
LALT1's Avatar
Thanks for the input guys, for what ever reason I never even thout about the seal between the two.
94TA how does the cc305 work without a stall?
Old Feb 6, 2003 | 08:48 AM
LALT1's Avatar
Doe sthe oil pan have to be removed on a LT1 or can you just drop it down? I am hoping that it can just be dropped down, but would like some info from someone with some previous expierence.
Old Feb 6, 2003 | 01:40 PM
94 TA TT2S's Avatar
If you are certain that you aren't leaking from around the timing cover I wouldn't change it....that can wait for cam change or something.....But as far as the seals on the timing cover go ahead and change all three while you have everything off.....If you decide to go ahead and change it....if you are extremely careful and not tear the oil pan gasket...you will not have to change it...But its up to you....
Old Feb 6, 2003 | 02:17 PM
LALT1's Avatar
I am going to go ahead and change the cam, thats why I was asking about how the CC305 works without a stall.
Old Feb 6, 2003 | 02:19 PM
MeanGreen97Z's Avatar
At 172,000 miles it is definately a good time to replace some gaskets and seals.
Old Feb 6, 2003 | 06:02 PM
97_TA_WS6's Avatar
Yea its either the WP seal or the Optispark seal. I replaced my opti put it all back together and started it up and after awhile it was leaking alot of oil. Had to take all back apart and replaced both the WP and Optispark seal and no more leaks. Except the leak at the back of the T-56 I have to replace the seal where the Driveshaft goes in I will replace that this weekend.
Adam 1997 Trans Am WS6 M6 has Borla cat back,LT4 knock module,subframes,Hypertech PP+,Hypertech 160 Thermostat,Air foil,Mac Pulley,K&N filter,B&M Ripper Shifter,MSD 8.5MM wires,Energy Suspension Trans mount & Torque Mount,1LE Driveshaft,MBA Silver Shift **** with WS6 ingraved on it,SLP 21mm Rear Sway bar,Viper GTS-R Carbon Kevlar syncros in a rebuilt T-56, Throttle Body Bypass and SLP pressure plate/clutch.
Dallas, TX
Old Feb 7, 2003 | 12:31 AM
94 TA TT2S's Avatar
the cc305 works fine without a stall thats how I am driving it now.....No big deal No problems....
Old Feb 7, 2003 | 06:37 AM
LALT1's Avatar
Does the CC305 have a good sound to it?
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
