pics of single turbo
Old Feb 5, 2003 | 05:17 PM
PaulN64's Avatar
Question pics of single turbo
anyone got instlall pics or pics of a LT1 with a single turbo?
Old Feb 5, 2003 | 05:39 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
now THAT would be awesome
I think were stuck with 2 though
Old Feb 5, 2003 | 05:42 PM
bad96firechikin's Avatar
Jordan Musser is working on a single turbo LT1 build up. You should PM him about it.
Old Feb 5, 2003 | 05:44 PM
KeVMaN's Avatar
how would you do that? have like a y pipe leading to a turbo? how where would you mount it where the pipe lenghts would be equal?
Old Feb 5, 2003 | 05:52 PM
Check out BMR suspension as well. They're doing a single-turbo f-body. It's not an LT1, but you'll get the idea. Basically a set of custom headers flow forward into a y-pipe. The turbo sits in front of the engine in most cases. I've never seen it done any other way. I guess theoretically you could run it off of one bank, but that would just be stupid b/c the flow would be different for both banks of the motor.
Old Feb 5, 2003 | 05:53 PM
Here is BMR's project:
http://www.bmrfabrication.com/Buildup1.htm
Old Feb 5, 2003 | 05:58 PM
SilverBulletWS6's Avatar
HRM....... Then whats this setup?????????
http://web.camaross.com/forums/showt...threadid=55923
Old Feb 5, 2003 | 06:13 PM
89irocz23's Avatar
heres a setup for turbo on a lt1 I found a while back.
http://www.detroitspeedworks.com/LT1-LS1%20FI.htm
Old Feb 5, 2003 | 06:36 PM
BigDaddy's Avatar
Check out www.turbotechnologyinc.com They use a turbo header on the driver's side, and a crossover pipe from the passenger side manifold/header that bolts to the back of the turbo header. The turbo mounts on the driver's side between the engine and shock tower.
Old Feb 5, 2003 | 07:28 PM
lbrowne's Avatar
would you guys do a hotcam and then install the turbo kit like on this page http://www.detroitspeedworks.com/LT1-LS1%20FI.htm ?
or is that spelling nuclear explosion....
Old Feb 5, 2003 | 07:31 PM
FastGuyJR's Avatar
The LT4 Hotcam is not an optimal cam for a turbo setup. Best bet is to have something custom-ground that's turbo-friendly.
JR
Old Feb 5, 2003 | 08:00 PM
lbrowne's Avatar
what about the stocker then?
Old Feb 5, 2003 | 09:25 PM
I think the LT4 hot cam would probably be an alright cam for a forced induction setup given it has very little overlap. Is this a wrong assumption?
Old Feb 5, 2003 | 10:21 PM
FastGuyJR's Avatar
The stock cam is ground on 116 or 117 LSA (lobe separation angle). The higher this number is, the less valve overlap there is. The hot cam is ground on a 112 LSA which has much more overlap. Most aftermarket LT1 naturally-aspirated cams are either 112 or 114 LSA.
JR
Old Feb 5, 2003 | 10:42 PM
kgkern01's Avatar
http://www.ls1motorsports.com/ has a 9 sec LS1 using stock crank single T-74 turbo. No turbos for LT1 though, but pretty fast.
