3" exhaust over the axle?
Old Feb 5, 2003 | 09:04 AM
94droptopz's Avatar
Is this possible? i want to run the 3"bullet muffler with a full 3" exhaust but i have ground effects with the dual exhaust cutout of the rear and want to fill it if possible. thanks
Rob
Old Feb 5, 2003 | 09:09 AM
ky94transam's Avatar
Am running a 3 1/2 inch over the axle.
Old Feb 5, 2003 | 09:16 AM
Thebeast431's Avatar
I have the GMMG chambered ehxaust and it goes over the axle and is also 3".
Old Feb 5, 2003 | 09:19 AM
teke184's Avatar
i'm confused
you mean a true dual 3" over the axle exhaust? if so it has been debated at lenght. very expensive and not easy. do a search, look for a guy named taner or tanner..he has it.
i all you mean is a single 3" pipe...that's what the majority of cat backs are, with the exception of mufflex 3.5" or 4"...which both run over the axle...
like i said i'm confused, your explaination is not very informative...
Old Feb 6, 2003 | 07:00 AM
94droptopz's Avatar
to explain more-id like to run true duals through an x pipe (3") over the axle so i can still use the cut outs in my ground effects. so yes can i fit two three inch pipes over me axle? thanks for the replys guys.
Old Feb 6, 2003 | 07:39 AM
'94 Bad A Z28's Avatar
If you want to run TRUtrue duals, why do you want to run 3"?
2.5" is perfect for true duals! Unless you're gonna be running some insane amount of boost, like say 30lbs on an LT1 , you don't need anything more than 2.5" with true duals.
Old Feb 6, 2003 | 09:55 AM
94droptopz's Avatar
well im not running any insane amount i just thought it would be better than 2.5, am i wrong? every little bit helps right?
Old Feb 6, 2003 | 11:36 AM
PatriotTA's Avatar
Well, to an extent. You don't want to lose back pressure with too large of a pipe. That equates to a loss in torque. 2.5" would be fine, and easier to run over the axle to boot. I am planning on running true duals sometime in the near future, and I'm going to be using 2.5" most likely. But hey, to each his own, just my .02
Old Feb 6, 2003 | 11:44 AM
bad95z28's Avatar
everyone has an opinion but i say go for the 3". i'm running duals w/ 3" pipe, x-pipe, and bullets. i have 3.73s, 2400 stall, and a bunch of other crap. that backpressure stuff is a bunch of bull**** in my opinion. why do people gain hp with cutouts? why do people run quicker ets with open headers? you may lose some down low but the gain up high will be worth it. i can tell you that i have NO PROBLEMS with low end torque but I don't spend much time below 2500 rpms either unless the convertor is locked up. what I do have a problem with is traction. so take it how you want but i say go with the 3" if you have many mods or plan many in the future.
Old Feb 7, 2003 | 11:41 AM
PatriotTA's Avatar
Where do your pipes dump? Stock locating, after the axle? Where are your mufflers? Any pics of the underside? Just lookin for ideas for my upcoming setup...
Old Feb 7, 2003 | 11:59 AM
Dr.Mudge's Avatar
Dual 3" is overkill, I had dual 3" and long tubes on my 69 Firebird 400 and it extremely loud, which can be nice I suppose, but it was way overkill indeed. I had to push my car about 4 blocks out of the neighborhood every day to start it, because I worked at 3:30 AM at that time.
Cop magnet, but it was nice
I think the Mustang guys get dual 2 1/8", as a point of reference.
Old Feb 7, 2003 | 12:41 PM
teke184's Avatar
checkout some of the true dual setups at www.laneswheels.com
you can also look into tanner's true duals over the axles. they were made by the same company:
http://community.webshots.com/user/ag385
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 7, 2015 03:01 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Ringmaster72
Apr 2, 2015 08:32 PM
