People with GM847 inside!
Old Feb 4, 2003 | 08:51 PM
Schurters LT1's Avatar
Just trying to find real people that have used this cam to get all the pro's and con's
Pistion to valve
cam kit
part #
where did it peak on the dyno
what kind of power numbers are you making on the dyno?
thx
Old Feb 4, 2003 | 09:39 PM
Grease's Avatar
Do a search for a board member called OneFlyn95z28. He's uses this cam and has run the car on a dyno.
It is also the cam I'm going with in about 2 months once I get my heads back from the machine shop. I'll be using it with the stock bottom end but I'm not sure where the heads will flow at. I hope to make 380+ rwhp but with well ported heads it shoiuld make over 400 rwhp. It falls into the same group as the XE 236/242 and GTP-6 cam.
RX Speed Works
Oct 1, 2015 10:19 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
