Need a fuel pump. Please give me some options...
Old Feb 3, 2003 | 04:56 PM
Smokn '94 Z's Avatar
Lightbulb Need a fuel pump. Please give me some options...
Well I think I am going to change my fuel pump. I am going to do the frowned upon cutting in the hatch to make an access panel method... Anyway what brand fuel pump should I go with? My car will have heads soon along with the Hot Cam that is in there now. Also do the aftermarket high volume/flow pumps directly replace the stock units? Or is there any fabricating that needs to be done..
Thanks again...
Old Feb 3, 2003 | 07:07 PM
Srper's Avatar
You can go with a Walbro 255l pump. They do not fit exactly in the stock bucket, but you can tweak the bucket to make it work. Someone correct me if I'm wrong, but I think a stock pump is good to 350hp. You might want to get a new stock pump.
Old Feb 3, 2003 | 07:41 PM
Dave19yz28's Avatar
I think granitelli makes a direct replacement (check out summit racing)...no modifications needed. But, im sure it costs an arm and a leg more than the walbro.
Old Feb 3, 2003 | 07:45 PM
Lightbulb
Yes. I know I will be pushing more HP than 350 RW so I wanted something bigger. I thought that there were more direct replacement performance fuel pumps out there.
Old Feb 3, 2003 | 08:07 PM
chevy94c's Avatar
You could try this http://www.racetronix.com/
Old Feb 4, 2003 | 06:28 AM
IDOXLR8's Avatar
I recommend going with a Walbro 255 lph
Old Feb 4, 2003 | 12:29 PM
SVT Killer LV's Avatar
lol... the GMS pump IS a granitelli.. just with the correct wiring harness... And yes you STILL have to mod the hanger assembly to get it to work... Trust me.. I am the fuel pump god.. lol..
Old Feb 4, 2003 | 03:23 PM
magius231's Avatar
Walboro 255LPH is what I went with...works fine for me. Here are some instructions for putting it in, although since your doing the access panel only the last part probably applies to you:
http://www.bfranker.badz28.com/fbody/fuelpump.htm
Old Feb 4, 2003 | 03:29 PM
chesee48's Avatar
i had a warblo intake but i couldnt afford the install, so im gonna go with a inline one...
Old Feb 4, 2003 | 03:48 PM
simple's Avatar
I 2nd that, they have excellent customer support, I believe they use the Walbro 307 and the bigger Walbro 340, do a search under their name on this board and you'll see what i'm saying!
cmyname1
Feb 19, 2015 08:38 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
