Vent Tube
Old Feb 3, 2003 | 03:37 PM
Fear The Z's Avatar
Question Vent Tube
I know that the vent tube that runs from the canister to the top of the fuel tank is off....I want to know is it hurting me any or do I need to find out a way to put this back on....
Old Feb 3, 2003 | 04:46 PM
Fear The Z's Avatar
ttt
Old Feb 3, 2003 | 07:16 PM
Fear The Z's Avatar
anyone?
Old Feb 3, 2003 | 11:23 PM
When the PCM opens the EEC purge solenoid, it is going to be sucking pure air into the intake, rather than the fuel vapor/air mix that will come out of a correctly functioning EEC system. The PCM should be able to compensate for that, using the long term fuel corrections (BLM's). But a vacuum leak - which is equivalent to what you have with the EEC canister not connected to the tank - hurts you some, because it drives the BLM's above 128, and when you go WOT, the PCM uses those higher values for fuel calculations, runs richer. Probably not a big error, but it should be fixed, or the line plugged temporarily.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Jul 10, 2015 02:23 PM
