Intercooler On A NA Motor??????
Old Feb 3, 2003 | 11:46 AM
COMNBYU's Avatar
i know its prolly a stupid Q, but why wouldnt a intercooler work on a NA application? i mean just as far as cooling the air down going into the motor. wouldnt that help some? or does it take a certain amount of psi to push air through one of those things??
just curious...
jon
Old Feb 3, 2003 | 11:59 AM
kgkern01's Avatar
An air to air intercooler wouldnt serve any purpose due to the fact that the air going in to the intercooler is not compressed and is already the same temp as the outside air, so that wouldnt do anything. Why an intercooler works in a turbo/superchgd car is when the air compresses, it heats up, which is why an intercooler helps to cool the air back down to give a denser air charge. An air to water intercooler I would think would be more effective if it is filled with something such as ice water to cool the air even further. If you did this with NA it would be effective I would think only in hot weather and with minimal effect, but then the added restriction may hinder the effect. I don't think it would be worth the time and money to try to install one on an NA car, where the less intake restriction the better.
Old Feb 3, 2003 | 12:10 PM
JeffSTAR's Avatar
N2O
N2O is the best "intercooler" you can use for a N/A application
Depending on the jetting, you can gain up to 200 rwhp
Old Feb 3, 2003 | 12:31 PM
neil350's Avatar
I was at the car show, and my buddy was telling me, some Import guys get intercoolers and consider it a cold air mod on there n/a car. A good cold air intake and say a ram air scoop is more than plenty on a n/a LT1.
Old Feb 3, 2003 | 12:36 PM
Javier97Z28's Avatar
Moderator
You'd just restrict your slow moving na air intake and slow your car down.. no good
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
TYLER94Z28
Dec 3, 2014 07:05 AM
