Code 29 in a 94 Z
Old Feb 2, 2003 | 10:07 PM
Screamer27's Avatar
Code 29 in a 94 Z
Code 29 is a code for the air system. What should I look for, or what can i test to get rid of this, it kicks my ses light on as soon as the car warms up, or starts, and kicks the fans on. If i just get rid of all of the air system, would that get rid of the light?
Old Feb 2, 2003 | 10:19 PM
1994TransAm's Avatar
your air pump as probly died...
replace or get rid of!!!!!!
Old Feb 2, 2003 | 10:21 PM
Screamer27's Avatar
so how hard is it to get rid of everything, any good tutorials?
Old Feb 2, 2003 | 10:40 PM
ok i'll tell ya how.....
first put the car on ramps
1. remove the pipes that come out of the exhaust manifolds (both sides)
2. remove the rubber tubing thats connected to the air intake (this isn't the elbow, this is rubber lines that go down towards the ground)
3. remove the 3 bolts that hold the air pump to the block
4. disconnect the harness that plugs into the air pump and also rubber hoese as well.
5. take a dremel tool and cut out the metal line that runs to both sides of the engine, its about 3/4 inch think, right against the front of the oil pan. tou can't miss it.
your gonna make 3 cuts on this pipe, be carful and dont forget to remove the bolt (1) that holds the pipe to the engine, otherwise its gonna get caught up
here are some sites:
first one is for 93 only .. but its similar!!!!!
http://www.geocities.com/MotorCity/6...3/egrpipes.htm
i'm not responsible for any damamge!!!!
Old Feb 2, 2003 | 10:44 PM
Screamer27's Avatar
ok thanks, 2 weeks ago i did plugs and wires, and everyone says that its hard to do. Hard, no. Time consuming, yes. I am just hoping that removing this will get rid of this light
Old Feb 2, 2003 | 11:17 PM
For your car you can probably get away with just unplugging the electrical connection to the AIR pump and then putting in a good fuse (the blown fuse triggers the SES). See if that does not work. Of course, if it does, you can junk any part of it you want to.
Old Feb 3, 2003 | 07:06 AM
Screamer27's Avatar
so there is a fuse for it. That is what will get rid of the ses light, ok. I'll have to look into it tonite when I get off work.
Old Feb 6, 2003 | 06:04 PM
Fear The Z's Avatar
Is it a fuse or a relay?
Old Feb 6, 2003 | 06:12 PM
There are both. Understand that you should be able to unplug the pump connector and make sure the fuse is in and good to keep the SES off. This is for an OBDI car.
Old Feb 8, 2003 | 11:58 AM
Screamer27's Avatar
i just replaced the fuse, and kept the pump plugged in, over 40 miles on it, and it didn't blow yet. so hopefully if i keep my fingers crossed it won't come back
Old Feb 8, 2003 | 02:27 PM
Fear The Z's Avatar
I should have just looked at the sticker on the damn cover Forgot i took the fuse out to let my friend use it for his fog lights
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
