Can I start the Z?
Old Feb 2, 2003 | 07:05 PM
97WRAITH's Avatar
Smile Can I start the Z?
I wanted to know if I can start it with now problems after taking off the egr tube and valve and also the air pump. I know the ses light will come on but will the car run ****ty with out getting pcmforless? Got the car back together wanted to start it to see how it sounds.
Thanks!
Rob.
Old Feb 2, 2003 | 07:51 PM
I guess so, if you blocked off the EGR stuff and plugged the AIR fittings.
Old Feb 2, 2003 | 07:53 PM
Z28ROC's Avatar
Can't see what it would hurt.
Old Feb 2, 2003 | 07:55 PM
97WRAITH's Avatar
anyone do this before?
Old Feb 2, 2003 | 10:29 PM
Josh'95Z28conv's Avatar
After installing headers, I blocked off the egr tube and removed the air pump, and it runs ok. I never reprogramed my pcm, but it seems to lack power under 2k. I talked to guys at lg motorsports, and tpis, and they couldnt tell me why. They said the pcm shouldnt need reprograming. Your car should run, but you may have the same problem. Can anyone tell me if this is my problem?
Old Feb 2, 2003 | 10:31 PM
By the way, I get no SES light either.
Old Feb 3, 2003 | 06:40 PM
97WRAITH's Avatar
Well I started it up. Wow sounds mean with the Hookers on.I didn't get any ses codes. I still can't drive it there is still snow down my street.Want to try it out next nice day 4.10's in Lt's in just have to send pcm in to Bryan for a tune.Thanks for the replies.
Rob.
Old Feb 3, 2003 | 06:42 PM
97WRAITH's Avatar
Forgot to ask you guys if anyone figured out a way to get the slip tube on the LT's to seal.
Old Feb 3, 2003 | 08:37 PM
Id like to know that too. mine leaks a little.
Old Feb 3, 2003 | 08:44 PM
Momar's Avatar
I have been told that if you use some permatex ultra copper on it it wont leak. I have a thirdgen with hooker long tubes with the slip fit primary but havnt got to run the car enough to know if it is going to leak yet.
Ben
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
