Would lightweight flywheel throw off balance of motor??
Old Feb 2, 2003 | 03:20 AM
lt1form's Avatar
Just like the title says, Do you guys know if a lightweight flywheel would throw the balance of the motor off ( cause any vibration )????
Or a smaller underdrive pulley???
Old Feb 2, 2003 | 07:54 PM
The flywheel has to be "specific" to the LT1, which is externally balanced, using a weight on the flywheel. As long as the light weight flywheel is for an LT1, with the weight on it, you will be fine.
The damper/pulley is just that.... a harmonic damper. It is not a balancer, and is neutral balanced. Changing the diameter of the damper/pulley will not change the balance.
Old Feb 3, 2003 | 01:31 AM
lt1form's Avatar
Thanks, Injuneer!
So can you install a lightweight flywheel on an existing stock motor, or does it have to be balanced at the machine shop with the entire rotating assembly?
Old Feb 3, 2003 | 02:22 AM
DjArcadian's Avatar
I had one installed and ever since I"ve had a slight vibration. After getting some new motor mounts and the harmonic balancer re-adjusted most of the vibration went away but much of it was still there which I believe is a result of my Star Spec flywheel. I'm not 100% sure as vibration can be caused by a number of things. I later put in a poly tranny mount which increased my vibrations a bit but after a few weeks they settled back down as the mount broke itself in.
Old Feb 3, 2003 | 05:13 AM
WayneE's Avatar
When I put in my Street Twin, I had the flywheel imbalance matched to my stock flywheel. It was very smooth. Then when I rebuilt my motor, I had it neutral balanced.
IMO if you're replacing your flywheel on a stock motor, take the new and old to a machine shop and have them get the balance the same.
Old Feb 4, 2003 | 11:50 PM
lt1form's Avatar
Thanks guys!
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
Jazsun
Dec 29, 2014 12:14 PM
