Pics of OVC wires with Mac OBDII style headers...here they are!!!
Old Feb 1, 2003 | 07:29 PM
DubbyZ28Camaro's Avatar
What do you think???
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Old Feb 1, 2003 | 11:04 PM
KLUCKS-SS's Avatar
Looks good!I can't wait to do headers.. But a question, what is the black box over the the driver side valve cover?I have a 97 m6 also and mine dose not have it what ever it is. Thanks..
Old Feb 2, 2003 | 12:01 AM
shocktrp's Avatar
Black box is ASR (traction control). It's connected to the throttle cable.
Old Feb 2, 2003 | 12:04 AM
KLUCKS-SS's Avatar
That is what that is..My SS did not(or as I recall none of the SS cars in 97)came with traction control. I just have never seen the traction cotrol box,or knew what it looks like. Thanks......
Old Feb 2, 2003 | 02:09 AM
usem's Avatar
Looks very nice... I have the same setup but on edelbrocks. Now how long did this job take you?
Old Feb 2, 2003 | 02:26 AM
PredatorZ28's Avatar
97 SS's did come with ASR if you ordered it
Old Feb 2, 2003 | 02:40 AM
Took me a while...I just worked on it an hour here and there so I didn't get so damn stressed. Probably a total of 8 hours total including removal of the old wires and installation/crimping/cutting of the new ones. It wasn't too bad but if you don't grease those damn boots up, they are a total PITA!!!
Thanks guys!!
Old Feb 2, 2003 | 03:15 AM
lt1form's Avatar
Very well done. Looks very nice,very clean job.
Old Feb 2, 2003 | 07:35 AM
96 TA's Avatar
Yep, thats what they should look like, good job! How did you like doing the opti ends?
Old Feb 2, 2003 | 11:37 AM
The opti ends SUCKED!!!! The first one I tried, I didn't use any sort of lube and it was impossible. After that I was lubing them too much and when I went to push them onto the opti, the boot would slide back!!! By the time I got to the passenger side, I knew what I was doing and the passenger side went MUCH quicker!!!
When I first tried to start the car it started and was running like crap and then I heard something rubbing!!! I shut the car off and found the battery wire rubbing on the belt. Luckily, it didn't break the insulation. I was just glad that one of my plug wires wasn't rubbing!!! Then it wouldn't start after that!!!! Well, turns out I mixed the #3 and #5 plug wires around. ALWAYS DOUBLE CHECK YOUR PLUG WIRE LOCATIONS!!!!
Thanks for the compliments!!
Old Feb 2, 2003 | 11:38 AM
Old Feb 2, 2003 | 11:53 AM
Shankels94TA's Avatar
Thumbs up
Looks Good. I want OTVC wires now! You need to scrap the traction control though.
Old Feb 2, 2003 | 11:56 AM
Oh trust me, I want to scrap the POS!!! I have heard that it takes a new ABS module and new wheel sensors or something along those lines and they are just too damn expensive for the time being. Plus I would need to get it programmed out of the computer (which I will have access to in a couple months). That is the next thing that I am going to randomly remove out of my engine compartment.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
GigaMp3z
Feb 20, 2003 02:57 PM
