Pop out of back speakers when i turn amp off!
Old Feb 1, 2003 | 04:37 PM
user guest 45's Avatar
Angry Pop out of back speakers when i turn amp off!
music plays perfect when amp is on...when i turn it off the back speakers pop! all connections are tight...any ideas....
Old Feb 1, 2003 | 05:11 PM
87LS's Avatar
I hate to say this but you have some bad wires, or a kink in them. Mine did this and that will make them pop a little, I don't know the pop you get but that is wat my problem was, I had a bad wire behind my face and that did it.
Old Feb 1, 2003 | 07:32 PM
do you mean rca'S
Old Feb 1, 2003 | 10:09 PM
LS1 RULZ's Avatar
Turn ON/OFF thumps are common in cheap equipment. What kind of amp are you using?
Old Feb 2, 2003 | 10:32 AM
i using good stuff Kicker KX600.4 amp
Infinity 6.5 speakers
Pioneer premier 930 radio...
Old Feb 2, 2003 | 11:25 AM
LS1 RULZ's Avatar
Your amp may be in need of some fine tuning then. A lot of amps use a timer circuit that keeps the power turned ON for a moment while a relay that connects/disconnects the outputs to the speakers has a chance to turn OFF first. If the power turns OFF while the outputs are still connected you get the popping noise you mentioned. Your amp is a 4 channel right? Is the popping only in the rear speakers? Try connecting the front speakers to the amp's rear channels and see if your front speakers pop as well. If this makes the fronts pop too then my guess, and it's just a guess, is that the amp has a problem somewhere with those channels.
Old Feb 2, 2003 | 02:44 PM
yes it is a four channel amp....
do you think maybe the amp is bad?
Old Feb 3, 2003 | 12:15 AM
robert_T's Avatar
bad Ground
Old Feb 3, 2003 | 10:05 AM
Jibberish18's Avatar
Gotta ask about your ground(s) and your lead turn on wire. Is it coming from your Stereo harness or from some other location like your fusebox?
Mad_Ice
Jul 29, 2002 09:44 PM
MilkyClr69
Jul 28, 2002 02:51 PM
Anderson
Jul 28, 2002 10:57 AM
Manaz101
Jul 18, 2002 09:39 AM
