Crank hub problems removing it
Old Feb 1, 2003 | 04:22 PM
Rodrigues's Avatar
I stuck a smaller bolt into the crank hub to push against the crank to remove the hub from the crankshaft. It was coming out then the bolt bottomed out, now the bolt is stuck in there and I cant get it out. I tried putting a socket in it but it wont go on. Any ideas? Did I do something wrong to the engine?
Old Feb 1, 2003 | 05:34 PM
LPEdave's Avatar
You'll have to explain that one better, at least for me to get it. If you used a smaller (thinner) bolt. it shouldn't thead in at all, it should just go in and bottom out inside the crank. I don't see how it would get stuck in there. Or did you use a bolt the same size as the stock crank bolt, but shorter?
Dave
Old Feb 1, 2003 | 05:51 PM
WayneE's Avatar
Hey Dave
I think I know what he did... he used a longer, thinner bolt in the crank snout. That bolt probably started to buckle inside the snout and is now jammed against the threads. I've seen this happen before, but unfortunately I don't know how to help out with removal.
Old Feb 1, 2003 | 06:51 PM
Rodrigues's Avatar
I got it, thanks for trying to help. WayneE was right, the bolt squished inside the crank hub and made a "S" shape. I got the bolt out by pounding the hub back in so I could grip the head of the bolt and I worked it out of the crankshaft. USE STRONG BOLTS WHEN DOING THIS!
Old Feb 1, 2003 | 07:21 PM
trax's Avatar
Ugh... I had the same thing happen to me. Luckily I caught it before it got jammed in there. Then I used a grade 8 bolt and I was fine.
Check the threads in the crank snout and make sure they're not messed up, too!
--Trax
Old Feb 1, 2003 | 11:29 PM
slashz28's Avatar
had the same thing happen to me a few weeks ago (its not funny just happy i could help ) i used a pair of needle nose pliers to get it out. mine was in there pretty bad. like completely crooked (yup, im a f**k up ) after about a half hour i managed to get it out. i was trying and trying to get it out, and it didnt want to, but if i remember correctly i think i managed to bend it a bit and then finally got it out. good luck. youll be fine.
Old Feb 1, 2003 | 11:34 PM
Jim S. '95 Z28's Avatar
Next time, just get the same size bolt as the stocker, just longer and grade 8 steel
Old Feb 2, 2003 | 05:59 AM
nateh's Avatar
I just had a similar thing happen, but the grade 8 bolt didn't get stuck. I was fortunate there. What happens is that the middle bolt on the puller gets slightly off center on the head of the bolt you've stuck in. I ended up using a 5/16 X 4" allen head bolt instead. The allen head forces the point of the puller to stay centered. It came off, but it was tight enough to mar the end of the puller and the bolt. The bolt didn't buckle though.
Old Feb 2, 2003 | 03:56 PM
96z's Avatar
96z
Try heating the hub up real good. Mine wouldnt budge for anything until I heated up real good. Slid right out after that.
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
