Solid motor and tranny mount????
Old Feb 1, 2003 | 01:34 PM
bigjoebull's Avatar
Do any of you run solid motor and tranny mounts or do you run polyurethane mounts? List what you run and if you like your combo or can you suggest a combo. My car is a 97z28 with Bmr control arms and pan-hard bar with polyurethane bushings.
Old Feb 1, 2003 | 03:08 PM
Red_94Formula's Avatar
I use Energy Susp poly in the tranny and motor mounts. I did the tranny first and noticed a little more vibe. Then I did the motor. While doing the motor I noticed the passenger side mount was collasped about an inch. I did not notice anything after installing them. I hear solid mounts are too harsh for a daily driver with big cam.
Old Feb 1, 2003 | 03:13 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
do NOT go solid
Old Feb 1, 2003 | 03:15 PM
WayneE's Avatar
I run poly tranny mount and poly motor mounts. Not too much vibe from my setup (heads/cam/long tubes/etc).
mattszm6
Dec 14, 2014 07:09 AM
Nostang 96z
Aug 31, 2002 12:01 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
