can someone tell me where these hoses from water pump gp to?? Pic inside
Old Feb 1, 2003 | 08:05 AM
LT1RX7's Avatar
I know here the larger 2 go to. But there are 3 smaller ones. I know two go to the heater core. Where does the other one go to? Can someone point me out which hose goes to what?
Old Feb 1, 2003 | 08:31 AM
Looking at your pic, the bottom right nipple goes to the oil cooler if you have one, or to the radiator if you don't.
Small upper left hose comes from the heater core
Small lower left hose goes to the heater core
You may have some other hoses, depending on whether you are bypassing the throttle body with coolant or not and what year hose configuration you are using.
There are expoded views on my Tech Page.
Old Feb 1, 2003 | 08:34 AM
LT1RX7's Avatar
The one that goes to the oil cooler, can I block that off? Or should I route it to the radiator?
Old Feb 1, 2003 | 09:53 AM
Someone else asked that question and I believe it was determined that it would be safe to block it off if you did not have a port on the radiator to connect it to. I think that person was doing a conversion, too.
Old Feb 1, 2003 | 02:11 PM
Mtrhds94Z's Avatar
The Corvette LT1 water pump doesn't have that 'bypass hose' connector at all on the pump, if that helps you any...
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
