Heads/cam 350 CI LT1 people.....post your **** dyno numbers already!
Old Feb 1, 2003 | 12:19 AM
canbaufo's Avatar
Arrow Heads/cam 350 CI LT1 people.....post your **** dyno numbers already!
.........ehhhh, please ?!? (for comparison's sake) (comparing to blown/stock LT1's of course) (please post or I will continue to pester )
Old Feb 1, 2003 | 12:49 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Run 004 - the other runs are my roommate's cars.
Old Feb 1, 2003 | 02:37 AM
OneFlyn95z28's Avatar
before and after runs
http://groups.msn.com/WashingtonFBod...to&PhotoID=440
It was worth it
also going for 11s N/A and deep tens on a 100 shot
Old Feb 2, 2003 | 01:00 AM
canbaufo's Avatar
Question
That's it ?!? No one else wants to brag about their numbers? Shawn, your numbers are pretty comparable to mine although you do have considerably less low RPM and max torque however ....considerably more RPM to use. OnFlynZ .....you must have a beast there, surely that's not a 350.
What cams/heads are you all using?
Someone else post they're numbers (or times) please and tell me what cam/heads you are using. Feel free to elaborate on MPG and off idle response, low RPM torque feel. I'm just second guessing whether or not I should have gone the heads/cam route instead and want some feedback as to max power and low RPM torque and/or feel/response.
Old Feb 2, 2003 | 01:43 AM
dobe's Avatar
395rwhp 373rwtq 137k mile bottom end w/ shot rings
Advanced Induction ported lt1 heads, AI's 211 cam.. i guess that would be a short name for it?
Old Feb 2, 2003 | 02:06 AM
stock ported LT1 heads for me...
best track ET has been an 11.91@117mph (negative DA that day) . I was on a 10 bolt @ that time. Best since then has been a 11.98@115 w/ my 12 bolt ~ in the summer.. another interesting note is I lost 30rwhp on the dyno after installing my 12 bolt, but the ET's don't really reflect it. partially due to the fact i now have a 3" steel DS vs. the 1LE.
Old Feb 2, 2003 | 02:19 AM
canbaufo's Avatar
Which cam? and what kind of loooow end does it have?
Old Feb 2, 2003 | 02:48 AM
Yes those numbers are off a stock short block with a .032 piston to deck. My heads are a combination of two porters. NightTrain66 and Dave of Flowtechinics. I was very sceptical of the flow numbers when I first saw them but the Raw HP of the end product backs them up.
It is a Beast that much is for sure. We were doing some fine tuning the other day and I nailed it at 55mph and it kicked sideways and carried the spin. I am putting a new set of Nitto 555RIIs on this week in hopes it will help traction some.
other then that it really is driveable. Can get hairy in the rain with the tight posi and 422 Lbs TQ down low but other then that very nice
BTW I only showed a 10hp loss with my Moser 12 bolt.
Old Feb 2, 2003 | 05:33 AM
jonaddis84's Avatar
Are all these numbers you are giving, oneflynz, on juice or N/A, I noticed you have a dry kit on your website but you dont mention it at all when talking about your dyno numbers?
Old Feb 2, 2003 | 08:14 AM
RealQuick's Avatar
#'s in the sig on stock homeproted heads.
Old Feb 2, 2003 | 09:18 AM
93ZM6Tally's Avatar
Numbers
Don't have track times yet - soon though.. Numbers in sig are with locally ported heads.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Dec 17, 2014 01:12 PM
Joe Brodman
Jul 24, 2002 05:24 AM
