Shade Tree Do it yourself cheap exhaust coating that works !
Old Feb 1, 2003 | 12:11 AM
NOMAD's Avatar
Cool Shade Tree Do it yourself cheap exhaust coating that works !
I'm amazed.... I went out and bought some cheapo hi temp paint at the Meijers store here. It's rated at 1200 degrees. My long tubes were rusting from not being coated, So i figured this would stick for a little while and at least hold to the bottom where the rust was worst near the ground. What the heck, it's only $4.99.
Here is the initial paint job
Now, after almsot 1,000 miles in snowy salty weather there are only 2 rust spots. Right near the bend in the primary where the exhaust is the hottest. none nowhere else, all the way back to the collectors.
You can sort of see my chromallusion valve covers in this pic (Which I did for less than $15 )
I must advise though, I used paint stripper and degreaser after sanding them down pretty good. Making sure there were no oils or residue on them made a huge difference i do believe
-Shannon
Old Feb 1, 2003 | 02:42 PM
Mtrhds94Z's Avatar
Do you have the actual brand name of the paint, etc?
Thanks!
Old Feb 1, 2003 | 10:50 PM
NOMAD's Avatar
Cool
Thanks!
I'll check tommorrow at the store. Liek I said, main reaosn I think it held so well so far is the fact i really stripped it down and layed as many coats on it as that can had
-Shannon
Old Feb 2, 2003 | 12:05 AM
shocktrp's Avatar
Glad it worked out for you. Look what happened when this guy tried it himself:
http://www.fbody.com/cgi-bin/lt1/rea...id=78936#78936
Old Feb 2, 2003 | 09:21 AM
NOMAD's Avatar
Cool
I think thats the exact same stuff I used... Lol...
I'm not sure if mine specified anything about exhaust though. Like I said, only place it's peeled is right at the first primary bend where the tubing gets the hottest. Yes, mine smoked like hell also, but I didn't warm it up all at once. I started, let it smoke a lil, shut it down... Over and over. I was mainly trying to get everything straight with the new engine, so I didn't want to run it at an extended period of time
Like I said, what are you out ? $4... lol
-Shannon
Old Feb 2, 2003 | 12:23 PM
94GreenZ28's Avatar
It looks like this guy was running really hot because if you look at the AIR fitting it is discolored. My one friend who has the same paint on the headers in his 4.3 doesn't look nearly as bad.
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
owen66
Nov 30, 2014 04:21 PM
Snoman73
Nov 17, 2014 07:22 PM
MJ_Z28
Aug 7, 2002 07:15 PM
