Pulled the alternator, can I bridge the wires?
Old Jan 31, 2003 | 07:03 PM
Dave 96TA's Avatar
Going out of town for a week, a friend needed to borrow my alternator while he gets his rebuilt. Of course without the alternator the circuit is broken and my alarm wont arm. Can I just temp rig a wire to connect the battery (+) wire to the plug-in connector at the bottom of the alternator? IE just want to complete the circuit so my alarm will be on while I'm out of town. thanks
Old Jan 31, 2003 | 07:06 PM
I don't see how taking the alt off is going to affect the alarm ( I admit I know nothing about alarms). The alt is bridged into the power system, not connected in series. The small wire is the "exciter" circuit that turns on the voltage regulator in the alt. I would not hook those two wires together.
BTW, insulate that big red wire so it touches nothing while it is off the alt.
Old Jan 31, 2003 | 07:09 PM
Dave 96TA's Avatar
nevermind
turns out the positive terminal on the battery was loose...
note to self, dont pull your alternator alone in the dark at midnight...
thanks shoebox, i might have just left it like that for a week if it werent for your reality check
Old Jan 31, 2003 | 07:17 PM
You have no power at all? I don't see how that is possible. Are you sure you did not remove one of the battery cables when you were removing the alt and forgot to put it back on?
You only removed the wire to the back of the alt and no others?
The big wire to the alt is three wayed on the positive battery cable at the battery. Of the two other cables, one goes to the starter and the other to the + block on the RH shock tower.
eazyZ
Mar 1, 2015 07:12 AM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
Omega9
Aug 2, 2002 12:33 AM
