Head replacement question.
Old Jan 31, 2003 | 03:50 PM
RPMdaddy65's Avatar
I'm installing a set of after market heads on a 95 Z28. When I removed the Banjo bolts on the back of the heads I noticed that it has a washer with some sort of rubber inner lining. After removing the heads I noticed that in the threads was the same material. Both of the rubber pieces the one in the head and on the washer were torn. I called the dealer and they said it was two washers and I just needed to replace both. Is this correct,because it looks like the one in the heads are made in it like a sleeve?Thanks for the help, Mike .
Old Jan 31, 2003 | 06:01 PM
n2ceptor's Avatar
According to the lt1 rebuild book , that is correct, just replace the rubber flat washers...
93Z Will
Old Jan 31, 2003 | 06:06 PM
nateh's Avatar
GM 10108689. You need 4, two for each side.
Old Jan 31, 2003 | 07:18 PM
RPMdaddy65's Avatar
Thanks a million.I'll get them ordered,Mike
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
