Power steering felp!
Old Jan 31, 2003 | 11:15 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Heathers PS stopped working suddenly last night. it has fluid. power steering works a LITTLE at high rpm(like 5k). I can see a few drips udner the car, but nothing big. I am thinking the pump is toast? no odd noises from it tho.
Old Feb 1, 2003 | 12:13 AM
my94blackz's Avatar
Mine does that!! If im sittin still wit clutch in pat the gas couple times the steering wheel locks it self up then frees itself back up only does it ocasionally though. It has went completly out before but then came bach like 5 min later
Old Feb 1, 2003 | 12:18 AM
NOMAD's Avatar
Cool
I have no PS until I rev to 2 grand, then it works fine. Pump is toast. I went through one already. Stick on a PS cooler and things shouldnt' be as bad after buyign a new pump. Heat kills those things.
I've got some small trans coolers if you wanna do that, just send me an email
-Shannon
Old Feb 1, 2003 | 12:34 AM
drop top steve's Avatar
Re: Power steering felp!
Inner rack seals can cause it, but you normally see a loose of fluid. Look and see if the boot ends have filled with fluid. Test gauge on ps pump if you have one. Does the rack have a internal control valve? Hell, toss a pump at it, it's a 50/50 chance and the easyest.
Old Feb 1, 2003 | 01:10 AM
Fatdog's Avatar
Cool
Look under the car. If the rack has oil all over it,then it's toast.On my third one now as we speak.My mechanic explained the lock up like this.---There is a piston type thing in there(The rack)and oil is slipping back and forth past the piston,(not supposed to),and then this locks it up as there is no place for the fluid to go.Hope this helps.(Did you folks notice this more when it's cold outside?)
mspennyhughes
Mar 1, 2015 03:50 PM
