Will I Gain More HP With New Injectors IF...
Old Jan 30, 2003 | 07:03 PM
Punisha69's Avatar
If i'm running lean? I have a pretty good tune right now... very rich... and i'm still running lean.. my injectors are at 96% duty cycle at WOT... if i get 32's... will this put down better numbers?
how much can the fuel pump provide?
whats the max HP people get with the Stock pump?
thanks
Old Jan 30, 2003 | 07:23 PM
rskrause's Avatar
Moderator
Re: Will I Gain More HP With New Injectors IF...
thanks
How do you know it's "lean", how lean is it, what mods do you have, etc.?
Rich Krause
Old Jan 30, 2003 | 07:31 PM
Punisha69's Avatar
will its lean cause the computer tells me it is?
ok.. mods..
355 CID, CC305/1.55RR's. RK Sport Headers.. cat back... CAI... WP... and, you know.. all the other goodies that goes with all that... hehe.
Old Jan 30, 2003 | 11:11 PM
sideways_Into_3rd's Avatar
u forgot to mention u have stage II heads dumbazz
his O2s are reading lean at wot .. ask matt what the readings were ... and if ur injectors are maxing out then YES U NEED BIGGER ONES .. since u already bought them then just stick them in...
Old Jan 31, 2003 | 12:30 AM
cef97ws6's Avatar
I would say the stock fuel pump is good for about 375 flywheel horsepower any more than that and I would consider an upgrade. With the CC305, good heads and headers an LT1 properly tuned should be capable of around 425+ flywheel horsepower. 30lb injectors should be plenty for your setup with about a 45psi fuel pressure.
Old Jan 31, 2003 | 12:35 AM
LPEdave's Avatar
My stock fuel pump was fine with 450fwhp...
Dave
cef97ws6's Avatar
Just thought of one other thing if you have stock fuel injectors you will need about 50 to 55 psi fuel pressure to maintain a reasonable duty cycle. This should be considered as a bandaid until you get larger injectors as it puts more electrical stress on the injector which could cause a failure over time.
Old Jan 31, 2003 | 12:42 AM
cef97ws6's Avatar
LPE Dave I am certainly not trying to say it is not possible for the stock pump to handle more I would just want a little insurance for a 375+ horsepower car. Look at the nitrous kits made for LT1's anything more than a 75 shot and they recommend an auxilliary fuel pump for that safety margin.
Old Jan 31, 2003 | 12:45 AM
LPEdave's Avatar
Nothing wrong with a bit of insurance, I'm just trying to help show what will actually work, so folks can tell where they do and don't need it.
Most of the time, an aux pump on a nitrous kit is made to raise fuel pressure about double, for a dry kit. That's kind of a different story.
Dave
Old Jan 31, 2003 | 01:08 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
dont forget to get the car tuned for bigger injectors
Old Jan 31, 2003 | 01:14 AM
cef97ws6's Avatar
LPE Dave I don't want to get in a big fuel debate with you but fuel pressure can be raised to 70+ psi with the stock pump but when you demand more fuel volume from it to make more horsepower whether it be Nitrous or just heads and cam it will not maintain enough volume of fuel to keep the pressure at a fixed value. Hence the need for an auxilliary pump not for pressure but for volume.
Old Jan 31, 2003 | 03:55 AM
well my stock pump CERTAINLY wouldnt hold volume at stock pressure past 4500 rpm !!! thats just a heads / cam car
let alone if it were set to higher pressure, the volume would probably die at 3000
Old Jan 31, 2003 | 02:30 PM
AlexA's Avatar
Stock FP, 30 lb injectors, stock fuel pressure - 390rwhp/415rwtq. RPM is what causes duty cycle issues. A "big" cam will continue to make power at higher RPM - this usually necessitates bigger injectors or more pressure because of the reduced amount of time available to shoot fuel.
I personally believe bigger injectors is the answer as the FP becomes less efficient at higher fuel pressure.
-Alex
13qtr
Oct 28, 2016 08:11 PM
93 RedBird
Nov 15, 2015 08:24 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
