Stressed Metal sound from brakes
Old Jan 30, 2003 | 05:00 PM
tireburnin's Avatar
I replaced my stock rotors and pads with Hawk pads and powerslot rotors about 2 months ago.
I noticed under moderate braking that I am getting a stressed metal kind of groan from the brakes. It sounds like when a big metal object (bridge or ship or something) is being stressed to its tolerances.
I don't hear the noise at normal stopping or during hard stopping. I have only done two really hard stops though and it stops incredably from 55mph.
The noise does go on and off so I thought possibly the abs??? But I only hear the sound from the front right brake. Stopping doesn't seem to be affected but the sound is a little unnerving.
What causes this?
Old Jan 30, 2003 | 05:21 PM
Maybe sticky caliper guide pins.
Old Jan 30, 2003 | 05:26 PM
tireburnin's Avatar
How would I fix that?
And seriously, Thank you Shoebox. Almost every question I have ever asked, you have had the answer too. I am always at your site too, for the install guides and pictures. I can't imagine the number of dollars you have saved me either.
Old Jan 30, 2003 | 05:38 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
maybe its the abs working PERFECTLY with your new brake system... like allowing the brakes to get to the very edge of braking without locking...? but i would trust shoebox over me... my .02
Old Jan 30, 2003 | 06:10 PM
The only way you can see if that is really it, is to take the caliper apart to check the pins. They should lubricated when you do a brake job, but I am guilty, myself, of not doing it. They also have boots on them to keep grunge out. The pins and boots are replaceable and if the pins are corroded, they should be replaced. Replace the boots if they are torn.
This is a view of a rear caliper and you can see where the pins are. The fronts are somewhat similar. The caliper bracket should slide easily and smoothly on the pins.
[edit] Front caliper. The mounting bolts are the guide pins.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
warmeck
Mar 22, 2015 06:43 PM
squarehead
Nov 21, 2014 08:02 PM
