Question on fuel cap/fuel tank...
Old Jan 30, 2003 | 02:48 PM
kmook's Avatar
Advanced Tech Moderator
According to an article on aeromotives site it says that
The stock fuel tank has a cap that both vents and seals
Now my question is, is a fuel tank suppose to be pressurized via the cap sealing, or non presurized via the cap venting? Reason i ask is i lost the stock fuel cap and replaced it with a locking one, since then when you take the cap off it releases a decent amount of pressure.
Anyone have some thoughts?
Old Jan 30, 2003 | 02:54 PM
'94 Bad A Z28's Avatar
Not too sure, I know mine is always pressurized when I take my stock cap off.
Bawls's Avatar
Mine releases a decent amount of pressure as well. It's a stock cap however.
I've noticed, the longer I wait to refuel the more pressure releases.
You got me...
Old Jan 30, 2003 | 03:46 PM
acayson's Avatar
I thought they held a vacuum, that is why they test your gas cap during an inspection with a vacuum pump. My cap always sounds like it is sucking air into the tank when the cap is taken off, not the other way around.
Old Jan 30, 2003 | 03:47 PM
Curious that they would say that. The cap is a non-vented type. They can't be talking about our cars. Ever notice that little round thing with a hose on it that is attached to the left rear brake hose bracket? That is the pressure/vacuum relief valve (vent).
Deadbolt24
Jan 19, 2015 01:29 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
guionM
9
Aug 29, 2002 01:48 PM
dansam
Jul 20, 2002 01:10 PM
